Home > For Sale > 4 pin diff, light weight battery, chinq radiator etc
All parts freshly removed from the fastest upside down skip in the world. This combination of parts made 175 bananas at 17 psi and ran a 13.9 1/4 mile at avon this year.
All prices are plus post. 5% of anything sold will be donated to the forum.
Short turbo engine - £450. Sold.
Standard low mileage block, honed.
Metro Turbo pistons on A+ rods with ARP bolts. Total seal piston rings.
CAM6581 Crank (turbo spec, factory hardened). Standard mains, 0.010" big ends. thrust face ground, thrusts bearings surface ground to suit and oil fed (both done by force racing).
Rotating assembly balanced.
New bearings through out (including cam).
Oil galleries drilled and tapped for removable bungs.
Avonbar phase 2 cam with light weight followers.
New oil and water pumps fitted at first build.
Centre main strap and proper high tensile bolts.
Turbo Dave Alu timing back plate, duplex timing gear.
Engine has done about 2000 miles since it was build, the bearings have done about a 1000 miles. It has good oil pressure and doesn't smoke, rattle etc.
GT1752 Turbo kit - £250 Sold
Good Gt1752 turbo - doesn't smoke, no noticeable play in the shaft.
Mated to a Metro T3 Manifold, well ported by Benross.
Braided oil Feed
7psi Actuator
Oil drain (version 73... this one doesn't leak)
Butchered saab down pipe. Mates to 2" exhaust. Should work in a mini, but may need slight adjustment.
Jack Night Straight Cut Drops - £125 SOLD
Tranex 4 pin diff - £125 SOLD
3.1 Crown Wheel and pinion - £50 Sold
RTS Clutch and flywheel - £150 SOLD
Megajolt Kit - £175 SOLD
Jon Fan modified plendindinum and T3 up pipe - £50 sold
Diet Battery - £50 SOLD
Weighs 6.5KG
Sick boy is not included
Landrover Intercooler - £40 sold
Bosch copy Fuel Pump and injection spec filter- £30 sold
K+N Filter - £10 sold
Slightly melted at the bottom where it caught the manifold. Doesn't leak.
Mercedes heater pump Sold
Bosch dump valve - £10 SOLD
Fuel Pressure Regulator
SOLD
Oil Pressure Gauge with metal supply pipe - sold wintersurfer
Oil temp gauge with Sender - £10 sold
2 Bar Boost Gauge
Sold
Old Sparko Bucket Seat - £20 - reserved
Oil catch tank - £10 - Sold
Garret flexible oil drain, fits GT series turbos - £10 - Sold
Oil cooler - £10
sold
1/2" hose joiner - £2.50 sold
32mm hose joiner with 1/8npt sensor hole - £10
sold
Brand new bosh heater/coolant re-circ pump -£40 sold
Nearly new brake bias valve (fits to bulkhead) - £20
Brand new Stebel Nortilous horn - fooking loud! - £20 SOLD
Metro turbo inlet manifold - £20
I can drill/tap the flat spot to 1/8 bsp for a boost/vacuum take of if needed.
MG Metro Rocker Cover - £10
Chinq radiator with fan and switch - £35 - reserved
Covered about 1000 miles.
All the lugs etc that mount it to the car have been removed.
Edited by apbellamy on 9th Dec, 2011.
is this the end of the skip!? :(
Mercedes heater pump for me and FPR
Edited by madmk1 on 19th Nov, 2011.
We both have minis that we want to get on with. Who knows what the future holds...
PM on the way.
hazpalmer
Member #: 9038
Carlisle, Cumbria
Shotgun the rts and jack knight drops. If you are willing to wait til payday. I can give a deposit in mean time.
I'm in no mad rush. Need a few days, maybe a week, to get the bits out of the box anyway.
tadge44
Member #: 2500
Buckinghamshire
Did you crash it, or something ?
Not crashed
Fortecphil
Member #: 7641
Jersey, CI
I'll have 2nd dibs on the Jack Knight drops please, if Haz drops out....
Craigie-B
Member #: 9468
Wootton Bassett
Interested in the megajolt, withnregardsmto the loom what do you mean by 3 wires to be joined together, is that till the loom is ready to use or any they connected to external parts such as a tacho? Sorry to be noobish just new to this stuff
I think you two need to update the build thread with the real nature of the demise of the shed
Interested in the K&N, but first, what is the ID of the neck?
Also interested in the dump valve depending on the part number
Edited by Sprocket on 19th Nov, 2011.
scott the joiner
Member #: 9229
newcastle upon tyne
Message through fb andy
its a sad day for multicoloured skips :(
davey_c
Member #: 9435
eire
i'd be interested in the fuel regulatorif you'll post to southern ireland?
wintersurferuk
Member #: 2208
oil presure please :)
It's not crashed or anything, it's just the right time.
Haz palmer has paid a deposit on them. I'll let you know if that doesn't work out.
You are second in line for it, I'll let you know what happens. I had to cut 3 wires to get the loom through the bulkhead.
60mm
0 280142103
OK, will have a look shortly
It's just time. Need to get on and play with proper small cars...
It's already been bagsied, but I'll get in touch if that doesn't work out.
PM on the way
Will update what's sold later on.
mayoturbo
Member #: 1395
chepstow
Is this why you are after 2 alloys? selling the van with a standard motor?
Frank is having the Ronals, so we need something to put on for the time being.
We're just going to see what happens with it...
bennyy
Member #: 9037
Doncaster, yorkshire
Sad to hear it lads, even sadder I have no money lol, good luck with the sale
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
end of the skip iam saddend .......but go forward guys
Don't be sad Steve! lol
List updated with stuff that people wanted.
just an OT thought....
if at some point you do think about resurecting the skip, how about swaping a pair of Rover subframs onto it with a K series....
then "tune ala Dennis" should be cheap and fun!
The posibilites are endless *smiley*
