| Home > Help Needed / General Tech Chat > Source for Dyno Test Results? | |||||||
14 Posts Member #: 9678 Member |
19th Nov, 2011 at 05:27:59pm
Can anybody tell me where there is a link to dyno test results for different engine build specs? I have only found one by AC Dodd at Mlmotorsport:
19th Nov, 2011 at 07:37:29pm
because there are too many variations in every aspect of an engine build that could see very different power figures. Which is also the same reason Vizard mentions little of final hp figures, but he does go through step by step why things work and don't work, what you might expect to gain or lose, and if you read the book from cover to cover, you would understand that.
Edited by Sprocket on 19th Nov, 2011. On 26th Oct, 2004 TurboDave16v said:
19th Nov, 2011 at 09:47:22pm
I read the yellow bible cover to cover when it used to be blue bible!.... And no way is it impossible to quote power figures based on engine build specs. The sad fact is most people don't know what sort of power to expect because they don't actually build engines, they just sell parts. Anyway, my question is are there any build specs with dyno tests out there other than the AC Dodd Mlmotorsport site? |
19th Nov, 2011 at 10:29:40pm
I never said it was impossible to quote power figures for a particular engine spec, just that tuners don't because if your final results do not match your expectations, you are going to complain.
20th Nov, 2011 at 08:21:14am
Have a look in the show us yours section. Plenty of spec's and respective power figures etc On 11th Feb, 2015 robert said:
20th Nov, 2011 at 05:09:54pm
Maybe we should start a sticky where everybody can post their build specs and results? |
