| Home > Help Needed / General Tech Chat > Best 1380 Head Gasket? | |||||||
14 Posts Member #: 9678 Member |
20th Nov, 2011 at 08:02:09pm
What is the best head gasket to use for an offset bore 1380cc? Does anybody make a gasket that will not overhang the bore? |
20th Nov, 2011 at 08:08:57pm
Cometic do I think. However a BK450 should do the job. If something is worth doing, it's worth doing half of. |
20th Nov, 2011 at 08:11:55pm
Me personally would use the AF460 for a 1380 or 1399. It has a slightly larger fire ring, and is a little thicker too, giving a bit more in the combustion chamber offsetting the increase in compression ratio a little those 73.5mm pistons give On 26th Oct, 2004 TurboDave16v said:
20th Nov, 2011 at 08:13:54pm
Even in a turbo application Colin? If something is worth doing, it's worth doing half of. |
20th Nov, 2011 at 08:16:11pm
I have been running with BK450 fine. I have started posting on Instagram also my name on there is turbomk1golf
20th Nov, 2011 at 08:21:04pm
On 20th Nov, 2011 John said:
Even in a turbo application Colin? Why not? what does the BK450 have that is superior to the AF460? If anything the AF460 will transfer heat from the fire ring to the block and head, much more eficiently with its lower steel face, and the upper copper face On 26th Oct, 2004 TurboDave16v said:
20th Nov, 2011 at 08:29:31pm
I dunno which is why I was asking. I've always used BK450 since going turbo. Always used copper before. If something is worth doing, it's worth doing half of. |
