Home > Show Us Yours! > 1275 GT Clubman - Rebuild
Wile E. Coyote
Member #: 7893
Portsmouth
Thanks for heads up with the wiring loom :)
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
Can't say I have....... I wonder if there is an industrial size Veet ? Haha
On 20th Feb, 2012 dig-mini said:
Have you tried wax on that there pubic hair
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
Evening all...... Found a little bit of welding I had to do, then the angle grinder blew up so off to Wickes who wanted £45 for one........ Got one from B&Q in the end £25 quid and same brand as the last one which lasted 3 years.
Managed to remove a lot of the rubber sound deadening matting too, just bits stuck on in various places still.
Jamie
Jamie.
I posted the cleaner off today, should be with you in the next couple of days. *happy*
You'll be smelling of oranges from now on. lol
Wile E. Coyote
Member #: 7893
Portsmouth
Brilliant :) thanks Mate :)
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
Today the old man put a coat of red oxide over the seam sealed areas, now it's completely ready for Stonechip to go on underneath.
I just spent a bit of time when I came in from work removing the horrible sound deadening crap and tarred on stuff inside again.
Slow but sure progress.
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
Hey all,
Question, the cover on the bulkhead that the wiring loom goes through,
I unfortunately ended up wrecking my one trying to get it off, I can’t find one on Minispares or eBay ?
What is it actually called ? ?
Thanks
Jamie
Jamie.
I have one going spare if you need one? Is it called the bulkhead closing panel?
Wile E. Coyote
Member #: 7893
Portsmouth
Oh wicked, That would be fantastic :)
I'll PM you and we can arrange how much £££ you want.
By the way the solvent cleaner works a treat, it really does the job it is intended for :)
Jamie.
dig-mini
Member #: 9269
Rotherham
Hows the stone chip painting going then or is that a job for tomorrow
Craig
Wile E. Coyote
Member #: 7893
Portsmouth
That Is today, Hope it turns out ok :)
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
Hey all!
Really rewarding and good day on the mini today, great progress and great for my enthusiasm having a bit of sun and seeing it come along another step 
See below;
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
Thought i would add a picci of the dog as well as he watches me out there all the time !
This took 3 and a half bottles to coat, I am more than chuffed with the quality and the finish of it, it is so easy to spray on as well *smiley*
Oh yeah, the guy in the overalls is me *happy**happy*
Edited by Wile E. Coyote on 25th Feb, 2012.
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
Plan next....... Get it rolled over and all interior and engine bay cleaned up and prepped :)
Jamie.
bennyy
Member #: 9037
Doncaster, yorkshire
looks a good job.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
wng691s clubby
Member #: 9252
Cleethorpes
it will all be worth it in the end
Done now needs redoing lol
dig-mini
Member #: 9269
Rotherham
Just as said its all good fun and easy to do
well done mate keep it up it looks cool
Craig
Wile E. Coyote
Member #: 7893
Portsmouth
Thanks alot guys *smiley*
Starting to get the buzz again now *smiley*
If I feel this chuffed after stone chip god knows how I will feel when I get it sprayed and finally get to drive it again.
*smiley*
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
Morning all,
I am looking at recoating my subframes with the Hammerite Yellow but spraying it on this time, having never sprayed from a compressor or the guns, i have Smooth Hammerite Yellow Paint.
How much should I thin it down ?
50 / 50 with some Cellulose thinners ? (I have a High Gloss Celly thinner)
Any tips on coating and recoating and application would be great,
Thanks
Jamie.
Jamie.
I think you'll need to use the hammerite thinners for smoothright - what does it say on the tim about thinning?
Wile E. Coyote
Member #: 7893
Portsmouth
Says not to thin :0/
Jamie.
There is some 'special' hammerite thinners, might be worth having a look on the thinners tin. *oh well*
I'd just thin it down to a 'normal' spraying thickness. Bascially the thickness of double cream. lol
Wile E. Coyote
Member #: 7893
Portsmouth
I have a little bit of "Smooth Yellow" So can give it a go.... see how i get on. Thanks Matt *happy*
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
Looks a bit more like a car again, up the right way at least *happy*
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
Reference my question earlier on thinning Hammerite Smooth, it says on tin not to thin it, but I think that is if you are brushing it on.
See link and below;
http://www.hammerite.co.uk/guide/direct_to...ooth_finish.jsp
Coventional spray application: Thin with Hammerite Brush Cleaner & Thinners at a ratio of 15% Thinners to Paint. Set spray gun at 25/35psi and use full fan spray at maximum volume. Apply 4 thin coats. Allow 1 hour between coats. Refer to spray equipment manufacturer's guidelines for the correct and safe use of sprayers.
Edited by Wile E. Coyote on 27th Feb, 2012.
Jamie.
