Home > Help Needed / General Tech Chat > Couple of Q's reg megajolt
Craigie-B
Member #: 9468
Wootton Bassett
Couple of questions guys:
Which fords can I get the crank sensor, EDIS and coilpack from? turbo-mini says 1995 festa but are there any others and was it only the fiesta made in 1995 with the parts I need? Or were there other years?
Again I got this image from Phil's site:
I was just wondering:
How do you wire the rev limiter in? do you go from the megajolt plug to the ignition switch on the coil pack and thats it?
Can you connect both the 12v connections from the megajolt and the EDIS together and then run them through the existing battery cable, or should I connect both the megajolt connections together put through a fuse and do the same with the EDIS and then connect them both together after the fuse and put on the main battery cable?
Tacho connector - do I use the megajolt plug, or the EDIS plug or both?
Cheers :)
Edit: Where can I get a dizzy plug from OTHER than MRA (loool)
Edited by Craigie-B on 24th Nov, 2011.
bennyy
Member #: 9037
Doncaster, yorkshire
There is some good info on the autosport labs website, and Dsn do a nice bullet alloy dizzy plug
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
There are lots of Fords that use the correct kit, Mondeos, Escorts, fiesta, lots.
'95 era sounds about right.
I can send you the wiring diagram for my sprint if it's any use? should answer all your questions.
Craigie-B
Member #: 9468
Wootton Bassett
Yes please wil_h that would be fantastic *happy*
will go scrap yard hunting
Thanks for replies guys *happy*
PM me your email and I'll ping it over. will be a bit later as it's not on my work laptop.
Craigie-B
Member #: 9468
Wootton Bassett
pm'd
No worries buddy thanks alot!!
Pottsy
Member #: 843
Stoke-on-Trent. Duck.
Something that had me scratching my head for ages and in the end I just had to trust the wiring diagrams; the Ford Edis unit I have uses brown wires for earth and black for 12v *oh well* Might be straight forward for others but that seemed a bit peculiar to me!
Ben H
Member #: 184
Melton Mowbray, Pie Country
That is standard ford colours. I agree it is daft, but it is what the septics do.
http://www.twin-turbo.co.uk
Beno174k
Member #: 9548
Manchester
Any chance of that email to ;p
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578
I got my edis stuff out of a couple of mid 90's escorts if it helps
I have a dizzy plug you can buy
*wink*
I'm struggling to find the flippin diagram. But I will so hang fire those who want it.
Craigie-B
Member #: 9468
Wootton Bassett
Thats cool buddy *smiley*
Madmk1 pm'd *smiley*
