Home > Help Needed / General Tech Chat > 15 mpg?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
What does your turbo mini do to the gallon!?!?
I expected it to be bad as its running very rich at the moment... just needs a setup me thinks!
Alex
AlexF
get around 25/28mpg on a run. Tons of advance, but I just can't get the mixture down to a sensible point without it pulling lean under boost (one problem running a T2 that makes so much boost at so little RPM).
I talked many times about using the part throttle 'lean off' pipe, but connecting a solenoid in it, so it closed at anything over 1/2 throttle, but never got round to it...
15 does sound a little too excessive however. No doubt you were playing mind!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
well the odd blip on the motorway just to see what see could do... oh and the country lanes... and and and...
Even so, 15 is loooow! My black one manages 10mpg on track LOL.
Alex
AlexF
Similar to Dave, around 25mpg on a steady run, about 15mpg running 1bar.
Phil. *smiley*
Would be interested to know what Miniwilliams gets ................*wink*
I remember Mike Cantello telling me he ran 26psi and got 4mpg......*oh well*
giallofly
Member #: 164
The Stig..
Newport Pagnell
They guzzle!!! *wink*
AllanMcD
Member #: 414
Dalbeattie Scotland
I run mine every day and get around 38mpg not much under 70mph.I use the lean off thing and high compresion and 9psi.
and a 2.76 diff with 5% high input gears.
http://www.rabdunn.co.uk/
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I guess a 3.7:1 diff isnt helpping my mpg either !!
Alex
AlexF
I use over a litre a mile, I never drive it part throttle mind.
