| Home > Help Needed / General Tech Chat > hks turbo timer | |||||||
![]() 161 Posts Member #: 9174 Advanced Member colchester essex |
24th Nov, 2011 at 05:13:57pm
hi guys i brought a hks turbo timer for my mini turbo and i cant work out how to fir it???
24th Nov, 2011 at 08:52:46pm
Ive got 1, u have to link it into ur 2 ignison wires and a permant live then earth the - and handbrake 1
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
25th Nov, 2011 at 05:01:06pm
Yer I know what you mean. Only thing is where do I put the hand brake cable wire as with the classic mini you don't have that wire! |
25th Nov, 2011 at 05:27:01pm
I suppose you could add a toggle switch down to earth to substitute the handbrake? On 26th Jan, 2012 Tom Fenton said:
25th Nov, 2011 at 05:47:16pm
Wat carl said, or just earth it pemantly 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
25th Nov, 2011 at 06:01:33pm
You didnt "brought" a turbo timer you "bought" one.
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
25th Nov, 2011 at 06:22:03pm
That don't work when I start the car it comes on but as soon as I stop the it stops? |
25th Nov, 2011 at 06:25:47pm
Here is my mobile number can you call me and I'll explain what a have done and see where I am going wrong? Or text me and I'll call you 07834718185 many thanks darren |
25th Nov, 2011 at 06:46:43pm
Red wire - 12volt live
25th Nov, 2011 at 06:51:10pm
I haven't got one but, Red should be permanent live, Green should be on with the 2nd click of the ignition powering the coil, blue should be on with the first click of the ignition and it sounds like you can earth the handbrake one permanently. Edited by Carlzilla on 25th Nov, 2011. On 26th Jan, 2012 Tom Fenton said:
25th Nov, 2011 at 06:59:25pm
That's what I have done? |
25th Nov, 2011 at 07:04:48pm
Think of it like this. The permanent live keeps it on when everything is off, the accessory when turned off, tells the timer to start operation, and the ignition feed powers the coil when the key is out, then after the set time turns off the ignition, turning off the engine as if you removed the key. The handbrake is probably a safety feature, so if the handbrake isn't on then the timer doesn't operate so the car doesn't run away! On 26th Jan, 2012 Tom Fenton said:
25th Nov, 2011 at 07:08:37pm
Yer I have done it like that the only thing I can think is I have wired it in just after the ignition not after the plug but will that make a differents |
25th Nov, 2011 at 07:20:17pm
id wire the ignition to the cars loom after the switch, should be white on the later looms, not sure if earlier looms share the same colour On 26th Jan, 2012 Tom Fenton said:
25th Nov, 2011 at 07:29:44pm
25th Nov, 2011 at 07:32:07pm
25th Nov, 2011 at 07:41:40pm
Does that mean I've got to name all the wires in the loom I'm making? That's going to take ages! On 11th Feb, 2015 robert said:
25th Nov, 2011 at 07:44:12pm
Nah, just the awesome ones. Imagine trying to read a wiring diagram with names on! On 26th Jan, 2012 Tom Fenton said:
25th Nov, 2011 at 07:55:57pm
Take turbo timer and put it back on eBay then just let your car run for a minute before getting out. Simples! If something is worth doing, it's worth doing half of. |
25th Nov, 2011 at 10:42:21pm
Mine does pick and choose wen it wants to work 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
