| Home > Help Needed / General Tech Chat > vac to boost transistion mis-fire | |||||||
18th Apr, 2005 at 10:09:46pm
Bearing in mind I have only just picked up the car... AlexF |
18th Apr, 2005 at 10:22:58pm
Is there any oil in the dashpot? On 17th Nov, 2014 Tom Fenton said:
18th Apr, 2005 at 10:28:24pm
LOL!
AlexF |
18th Apr, 2005 at 10:53:53pm
Heavier the better. I stopped using Valvoline 20/50 in my engine, but retained the 1/4 gallon I had left for the dashpot - it's a really heavy, almost treacle like goop!
Edited by turbodave16v on 18th Apr, 2005. On 17th Nov, 2014 Tom Fenton said:
19th Apr, 2005 at 09:24:23am
whats wrong with valvoline dave? On 15th May, 2009 TurboDave said:
567 Posts Member #: 102 Post Whore Pennsylvania USA |
19th Apr, 2005 at 09:58:57am
i use castrol GTX 20/50. |
19th Apr, 2005 at 10:21:50am
What about using ep90 in there ?
AlexF |
19th Apr, 2005 at 12:32:00pm
The famous oddball hose between the carb flange and RH side of the carb still connected ?? |
19th Apr, 2005 at 12:45:33pm
yes it is... not the original one thou...
AlexF |
19th Apr, 2005 at 03:11:33pm
Try blocking that hose completely. It does odd things to mixtures. Blocking the hose richens the mid range mixture and usually helps hesitation. Don´t know if it helps in your case but try it anyway. |
19th Apr, 2005 at 03:49:39pm
If I try the T-peiece trick will it lean the mid range?
AlexF |
19th Apr, 2005 at 03:56:42pm
Do as Jukka says, block the pipe with mole-grips or similar then take it for a spin.
19th Apr, 2005 at 07:07:19pm
i use neat stp oil treatment its thick as f@ck but works well and you dont hAVE TO TOP IT UP EVERY DAY. always looking for them bigger bunches of bannanas |
20th Apr, 2005 at 08:12:22pm
i thought it had just been on the rollers? |
20th Apr, 2005 at 09:42:30pm
It has...
AlexF |
