Home > Help Needed / General Tech Chat > R5gtt compressor wheel size
almichie
Member #: 2065
Has anyone got a standard compressor wheel to hand?
Could someone measure one for me please??
Shaft seems nice and snug
48,00mm od
33,95mm id
4,00 mm tip
trim 50
almichie
Member #: 2065
Thanks robert,
The compressor l is larger so this looks like a hybrid. How can I find out what the compressor is?
The housing has been machined, to a high standard
The actual wheel measures;
Outter 51.3mm
inner 39.7mm
tip 5mm
The casting has 518 in it beween two blades
Thanks, Al
Edited by almichie on 28th Nov, 2011.
58 trim t25 id guess, al .
a well above 200 bhp flow compressor on a 160 bhp turbine.
J5
Member #: 9689
Not such a good match then?
Ill check the turbine, maybe that's been up rated too....
