| Home > Help Needed / General Tech Chat > still getting top end cut out (death) | |||||||
26th Nov, 2011 at 10:22:42am
im still getting this top end 3rd and 4th cut out, it does it worst when i use 3rd to high revs then into 4th and it dies. seems to drop to idle and wont pick up?
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
3594 Posts Member #: 655 Post Whore Northern Ireland |
26th Nov, 2011 at 11:45:57am
Explain better.
26th Nov, 2011 at 11:51:07am
I agree with Steve,
26th Nov, 2011 at 01:06:46pm
Just been specking to ron and we think it culd be carb icing cause by it being a tad lean,
26th Nov, 2011 at 01:15:25pm
I can't see it being carb icing. Doesn't sound like the symptoms. with carb icing I found it ran ok at speed, but wouldn't tickover and was apain part throttle.
![]() 362 Posts Member #: 114 Senior Member Porto/Portugal |
26th Nov, 2011 at 01:28:52pm
Which air filter you have? Pedro Silva
26th Nov, 2011 at 01:58:50pm
I don't think its icing mate. If you say it's going up to the 13's on the AFR it's too lean. Either check you reg or give the needle a tweak.
26th Nov, 2011 at 02:19:16pm
fueling issue, if you havent an AEM lambda get one
26th Nov, 2011 at 03:12:03pm
Have got 1 benross, I think im going to change the jet to a richer 1 and profile a needle to suit
26th Nov, 2011 at 03:12:04pm
![]() 9326 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
26th Nov, 2011 at 04:02:26pm
Valve guides? |
26th Nov, 2011 at 04:25:36pm
On 26th Nov, 2011 eden7842 said:
Just been specking to ron and we think it culd be carb icing cause by it being a tad lean, Going to do some fettling I'll assume you are turbocharged, and I'll assume you mean the problem occurs at full throttle. Again you dont give any info. And I'll also assume you are in the UK...your info suggests that ( ie weather isnt that cold yet ) So based on that, there is absolutely ZERO chance it is the carb icing. Dont listen to ron whoever he is lol 9.85 @ 145mph
26th Nov, 2011 at 04:39:17pm
Nic why wuld it be valve guides,
26th Nov, 2011 at 04:48:56pm
You can't change the jet, well not for a bigger one. it's a standard part, the fuelling is set by needle profile.
26th Nov, 2011 at 05:28:32pm
Nic why wuld it be valve guides, Its very hard to describe It cant be that hard to describe, and you havent actually tried. Just give details about exactly when and under what conditions it happens. 9.85 @ 145mph
26th Nov, 2011 at 05:50:46pm
are you using the T piece mod / trick?
Edited by Brett on 26th Nov, 2011. Yes i moved to the darkside |
26th Nov, 2011 at 05:54:03pm
ive checked the float bowl, and pump.
26th Nov, 2011 at 06:06:55pm
Still sounds like lack of fuel supply.
26th Nov, 2011 at 06:07:50pm
what boost are you running?
My build thread..
26th Nov, 2011 at 06:14:27pm
Sounds like fuel supply to me too. More than likely down to a blocked filter in the tank or a worn fuel pump.
Edited by matty on 26th Nov, 2011. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
26th Nov, 2011 at 06:39:31pm
this could be Boost Bog, ie too rich, i have suffer with these symptoms once!
Edited by BENROSS on 26th Nov, 2011.
26th Nov, 2011 at 07:11:51pm
theres never any smoke, and its one of your heads benross.
26th Nov, 2011 at 07:14:49pm
However the noise when the valve guides nip up could be confused with a misfire to the inexperience ear, I'd put it down as a chatter noise myself.
26th Nov, 2011 at 07:44:24pm
A rich missfire will show up as a lean AFR on any wideband controller.
Edited by Sprocket on 26th Nov, 2011. On 26th Oct, 2004 TurboDave16v said:
26th Nov, 2011 at 08:12:50pm
theres never any smoke, and its one of your heads benross. from what everyone's saying i think it must be fuel, how do i go about richening top end even tho my needle is like a pin? Nobody has stated anything to do with the needle or richening the top end. You need fuel to the carburettor !! 9.85 @ 145mph
