Home > For Sale > BENROSS Cylinder Head
Okie dokie then.
I'm going to keep the head from the "Mighty Metro Van Upside Down Skip Of Doom!" as it's got slightly bigger valves and more port work, hence here I have for sale my BENROSS cylinder head.
Ported etc, 28cc Chambers, 35.7mm 214N race inlet valves, 29mm sodium filled turbo exhaust valve, Viton valve stem oil seals, Minispares double valve springs and bronze valve guides.
Helped my clubby make 132bhp and just over 140ft/lbs on 12psi at the TM RR day, this was on a 1310cc bottom end with 8.15:1 compression ratio and an Avonbar PH2 cam.
It has literally only done 300miles so is as good as new! Will obviously be a little bit dirtier now as it's been on the car. Will add more pics when I remove it.
£350 please!
c2_mad
Member #: 4215
hi mate...
first dibs please*happy*
you have a pm mate...
tadge44
Member #: 2500
Buckinghamshire
Can I be second in line please ?.
(For the cylinder head, that is )
This is prov sold.
josh_28
Member #: 9698
Pembrokeshire, Wales
Is it sold or still for sale?
Provisionally Sold! Should be picked up on Sunday.
SOLD!
