Home > Beginners Tech > GT17 Buying guide?
Goacher65
Member #: 9652
Maidstone, Kent
Does anyone know to a guide or info on exactly which cars to get a GT1752 turbo from? I know it's a 2.0l petrol saab 93 or 95 (not aero), but any idea of year etc?
Just seen this on ebay, but the inlet pipe looks far too long compared to others i've seen:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...d=p5197.c0.m619
Does anyone know which part numbers you're looking for on the part no. plate apart from gt1752, also, where is gt1752 stamped? On that plate or into the casting somewhere.
Planning to go and search a few local scrapyards so want to make sure i'm looking for the right thing before I spend some blood and sweat getting it off.
thanks
Howard
The one in your link is a VNT, easy to tell from the actuator.
You are looking at the right cars, around 98-2000.
This link here (courtesy of Colin (Sprocket) originally) will give you all the actual part numbers for a given series and reference which manufacturer (but not model of vehicle) uses them.
http://www.turbomaster.info/eng/catalogs/garrett.php
If there isn't an aluminium plate, the part number is usually etched into a machined flat bit of the aluminioum on the compressor housing - it is VERY difficult to read.
Goacher65
Member #: 9652
Maidstone, Kent
Would any of the ones listed there as being used by saab be a good one to use with a mirange manifold or simlar to save cutting bulkheads?
Rod: I have been reading your 1749/1752 comparison, trying to use it to help me understand it is that im looking for as well. Good stuff :)
The comparison in the thread you have looked at was really more about the difference between a GT17** and a GT17**V.
The difference between 49 and 52 is the compressor wheel diameter, and then you need to know the A/Rs as well to make sense of the information.
What I was showing in that thread was the way a VNT works.
There are only a couple of people on the forum using the VNTs at the moment so far as I'm aware (and that doesn't include me yet :) ).
So I would suggest staying clear of the VNTs for the moment until there is some more experience with them.
Goacher65
Member #: 9652
Maidstone, Kent
Ah okay, confusing stuff all this turbo malarky!
Goacher65
Member #: 9652
Maidstone, Kent
How much should I expect to pay for the turbo? Spoken to the local scrappy and they are asking 100 but to check condition first. If condition is okay does that sound reasonable? How much is excessive play in the shaft? Is a rebuilt kit expensive?
Edited by Goacher65 on 2nd Dec, 2011.
Goacher65
Member #: 9652
Maidstone, Kent
