Home > Help Needed / General Tech Chat > 7.5" disks
Looking for a set of solid disks for my car. ideally grooved and drilled.
Minispares offer some with a straight line grooves across them, but i seem to remember these cracking on Mr wood's car.
Seen some grooved ones on ebay from minispeed, but they don't seem able to tell me if the grooves are in the same places on each side.
Anybody got any suggestions or places to avoid? Won't be buying from minisport...
svrdaniels
Member #: 3600
Gateshead
The only ones that I am aware of are the Tarox ones available from minispeed
http://www.minispeed.co.uk/content/tarox-m...drilled-grooved
I would not bother, instead fit plain discs and spend the money saved on proper pads.
I have plain discs, mintex m1144 pads and minispares 7.5" calipers, and it is actually better than my 8.4" with blackstuff pads!
But im yet to deal with the likes of brake fade...
I've got the mintex pads already. *smiley*
the minispeed discs on ebay aren't drilled. not sure its worth £130 extra for a few holes...
What Mintex pads have you got, which grade?
NickG
Member #: 7912
Australia oi oi oi!
Ill put a few holeS In for free for you of you like lol :p
M1144 for Minispares alu 4 pots
Pay Carl to stick some holes in em for ya
That's an option i was considering
Yo-Han
Member #: 3228
North of the Netherlands
Nice timing; I have just bought a used 7.5" set-up and need disks aswell.
Mini Spares offer two plain disks:
"Normal"
"Upgraded quality"
Anyone notice any difference on the car?
Dazed and Confused....
Drill them yaself, theyre only soft iron
Alex
Member #: 1851
Woolavington, Zummerzet
I've had a play with a set of the Tarox drilled ones, and I wouldn't fit them.
Where the holes have been drilled, it is impossible to de-burr half of the outer facing holes as the drive flange is in the way. I have my concerns regarding pad longevity...
Unbolt the drive flange then. I dont think anyone on TM is particularly worried about how long there pads last otherwise we wouldnt build stupidly fast cars
Alex
Member #: 1851
You can't unbolt the drive flange on a 7.5" disk... it's kind of integral.
The burrs on the Tarox discs were so stupidly sharp that they would just rip through a pad. Stupid power or not, fitting something that you know is a bad part to you braking sytem is just lunacy.
carred
Member #: 9412
Austria
Slightly off topic, but could someone tell me if it's worth upgrading to 7.5" 4-pot calipers? Right now I got the stock 7.5" Cooper S setup.
Moreover would it also be worthwhile getting a brake servo?
wez
Member #: 9271
Stoke on Trent
you should be able to get in from the back with a whirly (de burring tool) to get the front side of the hole, also a flat file across the front of the disc and a round file through the hole would of removed the burr in the end as well.
Edited by wez on 3rd Dec, 2011.
one day boost will be mine!
Youre right, I had forgotten that since mine are 8.4" turned down to 7.5"
mw3
Member #: 9590
Derby
Doesnt drilling 'and' grooving brake discs tend to weaken them a lot and subject them to cracking, especiallu on the smaller discs?
I seem to remember being told to either go for one or the other?
Matt W
On 14th Mar, 2012 mw3 said:
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I got a set of grooved 7.5" disks from Min-its years ago (5 angled slots each side) and run them with the stock S calipers and 1144 pads for about 10+ years and 60k miles. No cracks, pads still have life in them and disks only need replacing now. I think the grooves help keep the pad/disc surface clear of debris and help life slightly.
On 7th Nov, 2008 Nic said:
naeJ
m
JT
Member #: 637
Hertfordshire
with holes and grooves you loose more area on a already small disc!
im going to run solid vented discs on the tubby
My build thread..
I've just ordered a set of non drilled, non grooved ones. It'll be right for my car.
