Home > Help Needed / General Tech Chat > wheels studs
wng691s clubby
Member #: 9252
Cleethorpes
im fitting metro turbo drive flanges and just wondered which wheel studs they require or if they are the same as the mini 8.4 disk drive flanges?
Done now needs redoing lol
eden7842
Member #: 8852
leicestershire
I belive there the same
They use the same nuts so your standard ones should be fine
wng691s clubby
Member #: 9252
Cleethorpes
cheers guys just that i read on here that they maybe different lengths as the flange is thinner. thought i best double check before ordering new ones
Ben H
Member #: 184
Melton Mowbray, Pie Country
The length is really determined by your wheels not the flange. In general alloys are much thicker than steel wheels.
If you have the wheel you are fitting do a trial fit and make sure the stud you are buying will be long enough.
http://www.twin-turbo.co.uk
