Home > Help Needed / General Tech Chat > fitting bolt in roll cage
JT
Member #: 637
Hertfordshire
hi
iv searched but couldn't find what im after.
iv nearly fitted my cage but was wondering if i need to drill a hole in each hole on the joining bars of the cage. (door bars, harness bar, roof diagonal).
so there would be 2 bolts at each end of the joining bars. or would one bolt at each end be ok?
thanks
josh
My build thread..
Drill a hole in a hole? Lol
JT
Member #: 637
Hertfordshire
lol yer theres 4 holes in the part that the bars go in.
hard to explain
the joining sleeves have 4 holes in them. do i need to put a bolt through all 4 of the holes in the joining sleeves?
My build thread..
I would of thought one would be enough tbh.
haimesyboi
Member #: 5702
Cornwall
What cage is it? Just don't use chocolate bolts.
mini93
Member #: 2017
Warwick.
guessing its a sleeved type door bar from safety devices, your drilling through the outter sleeve throught he doorbar.
Yes you need to drill all 4 holes in each sleeve, be 2 bolts holding the sleeve to the main cage and 2 bolts holding the sleeve to the door bar... and 4 further holes on the other end of the bar, there are 4 holes for a reason
David.
JT
Member #: 637
Hertfordshire
ok il drill the rest at the weekend
not sure if i will be able to get a nut on the on all of them though as its tight against the body in places.
My build thread..
