Home > Help Needed / General Tech Chat > Running Prob
Zeemax Power
Member #: 393
Oulton Park
I'm using a standard 1.3 carb mini at the moment and slowly its started to lose all its power, till last night it gave up the ghost, it still just about starts but hardly can move its self. When it was running it wasn't sounding like it was firing right but it didnt sound like it was just happening on one cylnider sounded like them all, In the past the car has had new plugs and leads regular, and the other day i cleaned the rotator arm. I was wondering if anyone had any thoughts on this and where would be the first place to start? Its the type module on the dizzy do these ever cause probs? Be greatiful of any ideas cheers
http://www.Zeemax.com
scott the joiner
Member #: 9229
newcastle upon tyne
I would try a compression test for starters as this could show up any problems along the lines of piston rings, valve seats in case its been run on unleaded without the hardened seats.
Zeemax Power
Member #: 393
Oulton Park
found the prob bust thanks for the input
dfid it do this last year in the winter? sounds very lean to me
Zeemax Power
Member #: 393
Oulton Park
Its quiet embrassing so i'd pefer not to say lol but its running fine again cheers peeps
Had you got your underpants on back to front?
Everyone does it at some point.
Go on, spill the beans.
For example, fitting the calipers with the bleed nipples at the bottom. I felt like a right tit when i realised!
Zeemax Power
Member #: 393
Oulton Park
Well basicly the exhaust is leakin on that crap clamp and the air box was sucking all the crap up and completely bloked the air filter and in turn blacked the plugs so all it needed really needed was new plugs and me to stop being lazy lol cheers for not making me feel to bad
