Home > Help Needed / General Tech Chat > Size of mini dash????
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
anyone got handy or know off the top of their head the width of a mini dash and also the height (i understand it varies through the dashboard i wanna know the tallest bit)
i got some perspex earlier but it is only 116cm wide and i'm not sure its going to be wide enough.
adam1330
Member #: 238
essex
i've got a walnut dash in front of me, width at the bottom is 119cm, width at the top is 114cm, and the highest part is 17.3cm.
hope this helps.
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
cheers mate ... the perspex i have is 116cm wide ...... 3 centimeters short ... anyone reckon i can still pull something out the bag with a little creativity? or will i need the full 119cm width?
adam1330
Member #: 238
essex
i reckon its possible, as its only 1.5cm each side, and thats at the bottom as well, maybe you could make up the extra bits with the pieces that you remove for dials etc..if you see what i mean? should hardly notice at all.
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
well the material is about 50cm deep, maybe more! i just cant believe it is 3 cm too short, i'll work something out!
Why not make some tidy looking brackets out of stainless or alloy at either side, e.g. make them a "feature" of the dash. Then you will also lose your 3cm gap?
your fitting a cage arn#t you? surley the dash will need trimming to fit between the cage
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
never thought about that! There is some lateral thinking for you!
good idea also Tom .... you lot are ever so handy! *tongue*
