Home > General Chat > Solid mounted rear subframe?
has anyone done it?
yep. Made my own steel brackets for the hillclimber. For a road car using the polly bushes is best.
I am sure jim has done it mate.
Why is it uncommon? I've found no problems with solid mounting my front subby, in fact it felt a thousand times more responsive!
my front subby is solid mounted already has been for years but rear subby always been rubber mound ive got 2 problems now though the new bushes i fitted are fooked after less than 10 miles and my diffuser will be easyer to mount half on the subby and half on the boot floor
i had a look for aluminium 'bushes' but dont seem to be available apparently
I'm sure Carl could turn you a set of bushes up easily enough
thats what im thinking
Bushes are easy to make, however every rear subframe I have fitted has always needed the trunnions pulling and tugging to get them to line up with the shell. Solid trunnions will only make this more difficult.
Like this mate
http://www.swiftune.com/Product/841/swiftu...d-bush-kit.aspx
Yes, the fitting is so random that no-one makes metal bushes.
Are you absolutely sure about that? *hehe!*
Like this mate
that is 1 problem i will have there was abit of pulling and tugging when the subframe went on
On our Miglia, there are no trunnions, just a simple right angle bracket bolted to the heelboard and welded to the subframe.
Thats how Jim has done his, after all, Jims car was built to Miglia spec, and he nicked all the same ideas from that Owens chap *hehe!*
Edited by Sprocket on 11th Dec, 2011.
G13B
Member #: 1376
here“s mine
The link is for Nylon bushes????????
Like this mate
So Nylon is not solid then?
I think we should be talking about durometer or Brinell, rather than 'solid' since rubber is a solid, but its durometer is toward the lower (soft) end of the scale
Like this mate
sooo... how much movement is in the nylon bushes? are they worth considering?
evolotion
Member #: 83
Glasgow, Scotland
none , there solid, without being pedantic.
Denis O'Brien.
all things considered, Nylon is pretty hard with a Rockwell hardness of around R110 to R120, which is harder than Human bones in most cases.
thats sorted then nylon it will be :) cheers lads
I never said Nylon in the first place. I know you can buy lots of nylon or polly ones. I was specific in saying that no-one made METAL ones.
The Nylon ones are great anyway.
Like this mate
