Home > Introduce Yourself > Long time lurker
Minuki
Member #: 9711
Luncarty, Perthshire
Hey guys!
I thought I'd finally join after lurking around for a while *tongue* My name is Scott, I'm 18 and I'm a photography student in Glasgow. I was bit by the Mini bug at a early age and currently have 2 Mini's. My first, a Mini Studio 2 powered by a 3 cylinder Suzuki engine named "Minuki" And my second, a 1990 Cooper RSP called "Sammy" which I will have on the road by April next year.
Because I have the Cooper, myself and my father have decided to go a bit nutty on Minuki *happy* I'm planning to turbo it and have it somewhat close to 500Kg's with 180bhp, which is should do very easily and reliably(The engine is turbo'd as standard in America) Is that weight figure realistic? I plan on using it on the road, so there will be sound deadening etc.
Anyway, enough rambling! Hello everyone!
Welcome to TM !!
is the suzuki engine out an early swift? ie the subaru justy cross over model if so ive seen 9k on stock internals there pretty cool motors turbo quite well too from what ive heard
Hello and welcome
Hello and welcome
wng691s clubby
Member #: 9252
Cleethorpes
welcome
Done now needs redoing lol
Sam
Member #: 1686
Oxford
Getting down to 500 kg takes some work.
Although its possible to get down to around 400kg as has been shown by Paul Wiginton. I think his aim for next year is to go below this mark.
Essentially, you need to look at every component and see if it can be lightened, made in a lighter material, or made in another way.
OMG Robert that's a big one
hazpalmer
Member #: 9038
Carlisle, Cumbria
Welcome and as said 500kg would be quite hard. Look at Paul's sprint and Chris dillows mini.
Welcome aboard.
welcome to TM
a warm welcome!
Welcome.
The choice of engine may well help you on the weight you are looking for :)
On 12th Dec, 2011 Minuki said:
500Kg's ............
......... Is that weight figure realistic? ...........
Do not underestimate how much work you will have to do to get near 500kg. Forget sound deadening for a start.
Minuki
Member #: 9711
Appreciate the welcome guys *happy*
I still have a lot of work to do on the Cooper before I'll be able to start on Minuki. If I find some time, I might post a quick build thread to show you lot where I'm at.
After reading some more builds, I've realised that having a road going Mini at 500kg is a little bit optimistic! *tongue*
