Home > Help Needed / General Tech Chat > Water direction
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Need help again guys, would I be right thinking the water direction for the heater comes from the top of the bottom hose, and is the direction of the main water feed from the bottom hose through the rad to the top hose, Thanks in advance.. Alan
Main Build
Upgrade to Turbo
Out of the head at number 4 and back into the top hose just before the water pump.
Andy....
Out of the head at number 4 and back into the BOTTOM hose just before the water pump.
Water allways flows hot to cold (or top to bottom)
that's what I meant. Brain and fingers are not connected today...
nala56
Member #: 9661
Sorry Guys, need to know does it start from no- 4 to heater from heater to top of bottom hose, Im fitting a Ka heater tap and need to know direction it goes through the tap, becuase its got an arrow on the tap for direction..
Main Build
Upgrade to Turbo
yep, comes out of the head at no4 and into the bottom hose.
