Home > Wanted > +20 rebored 998 block and other bits
jdisel
Member #: 9515
ireland
I'm on the look out for a cheap rebored block ready to go. Has to be +20 thou as i already have pistons to suit, Im also after more bits
-rear hilos,
-chrome rocker cover with fastners
-chrome (or pollished)7 x 13'' deepdish alloys, not bothered if the centre is sprayed a different colour
-uprated 2 core rad (preferabily minispares)
-a full set of guages - rpm, boost, oil temp, oil pressure, water temp, fuel pressure
-a wideband afr guage
-two 6'' or so speakers with an amp able to drive the speakers and a sub
-a set of chrome handles and winders
-dial guage
-a set of vernier callipers
Im on a bit of a budget so cant affort to pay mega bucks but if you have any few bits drop me a pm.
Another thing, i live in ireland so things will have to be posted but i can organise a courier if needed, so would need to see can i get a few bits in the box to make it worth my while with postage costs and everything.
JP
Edited by jdisel on 10th Jan, 2012.
A job worth doing is a job worth over doing
tonyl3
Member #: 9551
nuneaton
i have a good rad pm me
jdisel
Member #: 9515
ireland
pm'd
jdisel
Member #: 9515
ireland
bump
jdisel
Member #: 9515
ireland
Bump
adcyork
Member #: 6807
York
What pistons are you running? You're block is going to need a final hone with regards to the pistons you plan to fit.
jdisel
Member #: 9515
ireland
I think there the same as these http://www.minispares.com/Product.aspx?ty=pb&pid=38612.
But ill have to double check,
jdisel
Member #: 9515
ireland
anyone?
Why does everyone want rebored blocks?
Just get a standard one and have it bored to suit your pistons.
jdisel
Member #: 9515
ireland
I will probally end up just getting the one i have rebore, but just thought it would be cheaper to buy one off here already rebored as they seem to go fairly cheap here, my local engine machineist quoted me about €150 to get the block rebored and refaced, dont know if its good or bad price wise but its cheaper than another place i asked.
But i supose im better off machining my own block, at least i know its bored out to the right size for my pistons.
On 29th Jan, 2012 jdisel said:
But i suppose im better off machining my own block, at least i know its bored out to the right size for my pistons.
This is my point.
