Home > Help Needed / General Tech Chat > 1275 a+ crank pulley size?
Craigie-B
Member #: 9468
Wootton Bassett
Hey guys, looking to get a trigger wheel setup like turbo phil:
I cant find the dimensions of the bottom pulley? Do one of you guys have this to hand?
Craig
Get a Tom Fenton pulley, They are much better.
MINIMON
Member #: 863
Lathom, lancs
How much are said pulleys madmk1 and what are they like?
I was going to see about machining notches into the stock item but wasent sure if the O/D has to be of a certain size so buying might be abit easier than the above idea i came up with.
You will have to ask tom mate i have forgot.
wng691s clubby
Member #: 9252
Cleethorpes
around 40 quid i think thats you sending them a pulley to be worked on
Done now needs redoing lol
Craigie-B
Member #: 9468
Wootton Bassett
I thought he stopped doing these now?
edit: need a real quick turn around time as well
Edited by Craigie-B on 16th Dec, 2011.
jamie@thefatgarage
Member #: 9345
Sheffield
http://trigger-wheels.com/store/contents/en-uk/d30.html
fits a standard pulley..
Craigie-B
Member #: 9468
Wootton Bassett
Yeah ive seen that but dont fancy spending 40 on a wheel and then like 10 on new bolts
Getting a brand new bottom pulley should be on top of your priority list! Old A+ ones and A ones for that matter are JUNK!
Craigie-B
Member #: 9468
Wootton Bassett
why is that then?
They de laminate due to the rubber perishing between the two halves
There are some parts that just cannot be scrimped on
Craigie-B
Member #: 9468
Wootton Bassett
I see well in that case id better look for a tom fenton pulley or something, cant afford a med jobby unfortunatlet
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Triggerwheels .com, 40 pounds all done need a longer bolt..
Main Build
Upgrade to Turbo
