| Home > Help Needed / General Tech Chat > turbo oil feed fittings T3 and id of hose | |||||||
![]() 168 Posts Member #: 9709 Advanced Member Cirencester, glos |
18th Dec, 2011 at 05:44:55pm
hi guys i need and oil feed hose for my turbo. i just wounderd if the id of the hose matterd and had to be a specific size??? i have acess to 5mm id hydraulic hose and fittings. i understand that the oil feed for the turbo comes off the oil pressure switch hole which is 1/8?? i think. correct me if im worng. is this bsp or different?
18th Dec, 2011 at 05:55:13pm
I used -4 TFE hydraulic hose for my turbo.
18th Dec, 2011 at 05:55:41pm
1/8 BSP or NPT (they are virtually identical anyway) and 3/8 UNF for the turbo end. 5mm hose should be fine.
Edited by apbellamy on 18th Dec, 2011. On 11th Feb, 2015 robert said:
18th Dec, 2011 at 05:58:01pm
I'm just going by Joeys block pic :-
18th Dec, 2011 at 06:01:27pm
Which one? the one with the right thread or the one with the wrong thread on it? I'm certain it's 1/8. On 11th Feb, 2015 robert said:
18th Dec, 2011 at 06:12:01pm
any clarification on which one it is 1/8 or 1/4??
18th Dec, 2011 at 06:22:36pm
I have a braided t3 feed in the garage i bought off simon, ill go measure it for you. I know it has one banjo 90 degrees out to the other one down the length. So if you laid it flat on the table, one banjo would be horizonal, and the other vertical.
18th Dec, 2011 at 06:24:23pm
1/8
18th Dec, 2011 at 06:27:47pm
18th Dec, 2011 at 06:28:02pm
The hose is 25.5" long tip to tip.
18th Dec, 2011 at 06:30:31pm
cheers bellamy for that link |
18th Dec, 2011 at 06:32:56pm
cheers to joe aswell |
18th Dec, 2011 at 06:33:57pm
Not a problem chap. Glad to be of some help! On 26th Jan, 2012 Tom Fenton said:
you been alot of help
