| Home > Introduce Yourself > Hi im new on here. | |||||||
6 Posts Member #: 9717 Junior Member Guernsey Channel Islands |
18th Dec, 2011 at 08:39:06pm
This is my first time on here, my name is Adrian and live in Guernsey channle islands.
18th Dec, 2011 at 08:43:51pm
welcome, best place for a turbo is the likes of benross or turbo phil. Pistons your looking at omegas either cast or forged. You can get a set of plus 20 thou omegas, 10cc for £300. And cam wise, for fast road a mg metro is always a good choice or a SW5 or kent 266. |
18th Dec, 2011 at 08:45:31pm
what sort of power are you after?
18th Dec, 2011 at 09:06:23pm
Thanx for the info, has comfirmed a few things, you see a few names coming up, an the names and make of parts seem to be the most popular, as for power,
18th Dec, 2011 at 09:19:34pm
160 should be fairly easy to achive,
18th Dec, 2011 at 09:48:17pm
Well i wont to get as much as i can, i only ues it at weekends and for charity events like hill climbs and sprints, so wont be out every day. Its my toy really,
18th Dec, 2011 at 09:52:24pm
you can get similar power from the t3, might need a slight bit more boost, but the gt17 boosts from lower down, If you have the T3 certainy use that, at least at first.
18th Dec, 2011 at 10:07:59pm
Will stay with the t3 then and see how i go.
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
19th Dec, 2011 at 06:36:59am
welcome i think people avoid the 1.5 rockers and tend to go more with the 1.3s but i think it may just be down to personal choice Done now needs redoing lol |
19th Dec, 2011 at 08:32:38am
Hello and welcome.
19th Dec, 2011 at 03:23:45pm
a warm welcome!
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
19th Dec, 2011 at 07:12:16pm
Welcome.All the Midget stuff will fit,type 9 should be fine,but the rear axle will give up if you use that performance,so think about upgraded shafts at least.Agree with Anton fit Megajolt and get it mapped,otherwise the rebuilds are expensive(and regular) 'Where does the engine go?' |
19th Dec, 2011 at 07:15:27pm
Id like to say welcome and a big thankyou on behalf of the TM team for donating within 4 posts
I seriously doubt it! |
19th Dec, 2011 at 09:43:39pm
Sorry if I seem a bit dumb,
19th Dec, 2011 at 09:52:58pm
megajolt is a 3d mapable ignition, you can get the timing closer to what you need over a wider range, especially part throttle.
19th Dec, 2011 at 10:12:55pm
Thank you Joe
20th Dec, 2011 at 09:47:26am
a warm welcome to TM |
20th Dec, 2011 at 07:04:50pm
All sounds like a good plan.I tore the teeth off first gear on my SCCR box,and twisted a competition half shaft,but your trans/axle should cope!I run an almost identical engine spec.including 1.5 rockers,but with a GT17.Last time on the RR gave around 170 bhp at 17psi boost. 'Where does the engine go?' |
