Home > Help Needed / General Tech Chat > Su Carb
Zeemax Power
Member #: 393
Oulton Park
I was wondering if someone knew the model of my su carb, its off a standard 1275 1993 carb mini. Why i want to no is i want a filter and knowin my luck i'll order the wrong one lol.
http://www.Zeemax.com
Probably a HIF44. Whip up a pic and one of us will soon tell you!
100ev8
Member #: 9138
wolves
hif 38 at a guess
http://www.fishfight.net/
100ev8
Member #: 9138
wolves
did they fit a 44 to a std mini ?
38 on 998 metros and mini 1275s and 44 on metro 1275s
dig-mini
Member #: 9269
Rotherham
I boughty off ebay about a month ago k reg thinking this will be a 44 nop it was a hif38 waste of £40 *frown*
Craig
My mate is looking for a 38...
Zeemax Power
Member #: 393
Oulton Park
Is there an easy way to tell the difference ie: markings on it?
All i really could do with knowin whats the diff between HS4 1-1/2" and HIF6/44" and which is more likely to fit my car cos i cant tell the diff by looking at each of the diff filters
Late non cooper 1275 mini's had 38's on.
HS carb has an external float chamber for a start. Also measure the opening of the carb at the butterfly end. 44mm=HIF44
1.5" carb. Float bowl integral is a hif38, on the side a hs4.
1.75" carb, float bowl integral is a hif44, on the side a hs6.
100ev8
Member #: 9138
wolves
remove the elbow and measure the hole
Zeemax Power
Member #: 393
Oulton Park
thanks for the help everyone, measured it today and it was 38mm so anyone else who has a 1993 spirte head up for you lol, disapointed though cos measured my old turbo carb and that was a 44mm and i take it bigger means better
anyone no brake horse between the two? or is that a little sad lol
davey_c
Member #: 9435
eire
bigger isn't nessicarily better, if its too big you will loose power, the hif38 is actualy quite decent on a standard 1275. a turbo would need more fuel/air mix hense the bigger carb
hif38 would probably give more torque lower down the revs on a standard-ish 1275.
I actually noticed the difference in low down torque when i swapped from my hs4 to a hif44 on my old engine. I'd already taken the plunge and bought the hif, but they're better designed imo.
