| Home > General Chat > OT/ I guess no one on here knows much about fixing welders? | |||||||
20th Dec, 2011 at 07:46:15pm
I have been getting on pretty well with the welding on the mini until last week when the wire feed on the MIG stopped feeding wire. I have took it apart and the relay is ticking when the trigger is pulled (so I presume its doing its job) but the wire to the wire feed motor has no power. The wire feed motor or gearbox isn't jammed either. Any ideas? Its a SIP T150P. I won't get it in to be fixed until after christmas so wont get to do much on the car over the break On 7th Nov, 2008 Nic said:
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
20th Dec, 2011 at 07:48:53pm
Try here: http://www.mig-welding.co.uk/forum/index.php :) [X] nail here for new monitor |
20th Dec, 2011 at 07:49:19pm
BFH? I seriously doubt it! |
20th Dec, 2011 at 07:50:00pm
never assume :) most likely the relay is burnt out, but it could be the power supply that supplies the motor is dead, or the motor itself is dead, youll need to test a bit more thoroughly :) turbo 16v k-series 11.9@118.9 :)
20th Dec, 2011 at 08:45:21pm
I will have another look, the relay is mounted directly on a circuit board so I know its getting power but the leads from the circuit to the motor are dead. In that sense I can't test the output at the relay directly. Hmmm, I guess it could be the relay then. Haven't been impressed with the welder (the torch has broke countless times) but then it is a "hobby welder" after all. Thanks guys! On 7th Nov, 2008 Nic said:
20th Dec, 2011 at 08:47:29pm
Sips are a bit shit,
20th Dec, 2011 at 08:49:31pm
Arent the wire feed mechanisms absolute shite on SIP welders?
20th Dec, 2011 at 09:16:35pm
I have used two different SIP welders in over 25 years -the second one is only 5 years old.No problems with the first one, but SIP themselves told me that the quality is down on 25 years ago.
