Home > Help Needed / General Tech Chat > mini dizzy
wcchoppr
Member #: 443
Harrogate area
Doesn anyone have any insite on how to stop the damn mini from cutting out when it is wet? My mini runs like s**t and eventually cuts out when there is even dense fog. How can i keep the water from my dizzy?
Grant
Nick
Member #: 154
Midlands
get a rubber glove, cut the ends of the fingers off and feed the ht leads through each one with it over the dizzy, secure with tie wraps, jobs a goodun.
wcchoppr
Member #: 443
Harrogate area
right, maybe ill try some little moisture absorbing packs that you get with a pair of shoes too lol. Thanks for the help
Grant
good condition ignition system works wonders *smiley* all std lucas stuff does the trick. ive never had a problem in the wet with bog std metro leccy ignition
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
haha genius!
I'm welsh, I have 8 fingers, what would I do with the spare ones?
Kean
Member #: 341
aka T2clubby
South Staffs
LMFAO!!!!
*happy**happy**happy**happy**happy*
T3Tone
Member #: 252
Sunny suffolk
that could be used as a drain pipe,any moisture that does get it can just drain away:)
-MINI CLUBMAN 1380 TURBO-
