Home > For Sale > 1399 block pistons and crank
shellspeed
Member #: 9580
Surrey
I have an A plus block honed and skimmed flat to 74mm
4 pistons stamped +0.20" and 1010 N10 (used but inspected). with new rings
new mains and big ends fitted
crank re ground
all machining carried out at Classic and Modern in Bracknell
Engine was assembled about 2 years ago but has never been used or run so should be re lubricated before use
Its clean and painted but could do with a touch up
Just gathering dust now as its not required £250 collect from Camberley or Shepperton only unless you want to arrange a carrier
James
Edited by shellspeed on 22nd Dec, 2011.
For future reference please put all your For Sale stuff in one single advert
mjpuds
Member #: 9099
is this still for sale any idea if there is a cam fitted if so what . and were the bearings new in cam.
shellspeed
Member #: 9580
Surrey
No cam or cam bearings or followers
mjpuds
Member #: 9099
are there bearings fitted to crank. and last one ...has the center strap been drilled.sadly just finished and fitted 1380 but it has seized so i guess it time to replace block...sadly all new bearings ..must of been a blocked oil way some where..
Edited by mjpuds on 31st Dec, 2011.
