Home > Help Needed / General Tech Chat > Megajolt question
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
Hi.
I have my mind set on a Megajolt setup.
I need to buy it with MAP sensor, but should i choose Tacho driver aswell ?
Thanks
If i have more toys than you when i die, I WIN
map sensor for a turbo.
dig-mini
Member #: 9269
Rotherham
Yes if you want to run a tacho
I have mpi clocks in mine and it works with out just taken a wire to the coil pack. If your using the carb version 3 clocks it works but will show double the rpm. This is what happened on mine.
Craig
TurboTom
Member #: 7936
Thanks
I´ll order it with tacho driver then.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Do you mean half the rpm, not double.
The standard clocks work from the EDIS output, but if there is an option for a tacho output i would include it, saves a lot of hasle later.
http://www.twin-turbo.co.uk
nala56
Member #: 9661
Sheffield South Yorkshire GB.
I ran mine from edis pin, and works fine some older clocks do have problems.. Alan
Main Build
Upgrade to Turbo
colas
Member #: 102
Pennsylvania USA
Which pin on the Tach do you use
nala56
Member #: 9661
On the edis4 I'ts pin 7.. Alan
Main Build
Upgrade to Turbo
dig-mini
Member #: 9269
Rotherham
Yes thats right I no what I mean I think LOL
Craig
