Home > Help Needed / General Tech Chat > Bulkhead sealing plate
Billus89
Member #: 8931
I am in the process of cleaning up my original bulkhead sealing plate (the large black plate that sits behind a centre of the dash and runs the wiring loom through it via a grommt). The only problem is that I dont have the bolts or fastenings needed to pout it in place.
Does anyone know what thread and length they are, or have any spare?
Many thanks *happy*
nala56
Member #: 9661
Sheffield South Yorkshire GB.
1/4 unf
Main Build
Upgrade to Turbo
Billus89
Member #: 8931
Thanks alot matey. :)
easy enough to run an M6 tap through the nuts and use a more comon M6 screw. Its not as if it's going to be carrying any load.
On 23rd Dec, 2011 nala56 said:
1/4 unf
You sure? Mine are 2BA
wng691s clubby
Member #: 9252
Cleethorpes
somerford minis will sell the correct ones
Done now needs redoing lol
nala56
Member #: 9661
Thats what mine were before I moded the bulkhead, maybe someone made them a bigger size before I owned the car, sorry if I got It wrong.. Alan
Main Build
Upgrade to Turbo
They're 1/4unf in my shells
Perhaps its just MK1s that are 2BA then
nala56
Member #: 9661
My Mini is a mk1 Paul, but I did not have the car from new has I said before, so could have been done before I aquired it, if I were Billus89 I would do what Sprocket says to do, I would open it up and put an m6 tap through it, More available, can buy them anywhere.. Alan
Main Build
Upgrade to Turbo
After a lot of searching for my car... 11/32 UNF x 3/4" aka no 10 panhead screws.
ado15
Member #: 9838
11/32" ?? Surely not. That's huge!
10-32 UNF is 3/16". This is the correct size for the panel you refer to.
2BA and M5 are very close to this, so can easily be mistaken.
Steve
DSN Classics Ltd
www.dsnclassics.co.uk
I was just having a look at that, thinking I had ordered the wrong bolts. Had to dig through somerford's catalogue again. It is 10-32 UNF... little typo on my part.
Billus89
Member #: 8931
Hi Andy,
I used somerford aswell to get the correct screws. Safe to say that the plate is now fitted :)
Craigie-B
Member #: 9468
Wootton Bassett
tigerseal ftw
