Home > Help Needed / General Tech Chat > Hydraullic handbrake legal or not?
sam_shelton
Member #: 251
Nottingham UK
Does anyone know if a hydraulic handbrake is MOT legal on a road car. WRC cars are road legal have them so maybe they are?
my understanding is it has to be a different system, so if you have a seperate caliper, and master cylinder then it should be, but I'm not 100% sure on that
No, full stop so ive been told
Dangerous
Member #: 417
I thought they made a hyd handbrake that can have the cables attached for roaduse
The law on this is that there has to be a handbrake that is actuated by MECHANICAL means to give you half a chance in the event of complete hydraulic failure. So if you have hyd master cylinder attatched to your rear brakes for a hyd handbrake, but leave the cable in place as well, you will be legal. Why you would want for the road though I don't know? I have put them on stage rally cars but for the road???
sam_shelton
Member #: 251
Nottingham UK
well I am builidng a race inspired mini which I want to use for hillclimbs, tarmac rally, sprints and drag events but also want to be able to drive it on the roads. The aim of the hydraullic handbrake is for the tarmac rally use where I think it maybe useful.
cheers
Sam
The trick is to have a cable still installed that appears to be doing something but isn't really. i.e. a cable that is attached to the handbrake lever and a token lever that goes into the drum. Pull the handbrake and the cable moves (moving the lever) and hey-presto the hanbrake comes on, or something like that.
They can't take things apart on an MOT to check if they are 'inependant' systems so they'll have to pass it.
Does that make sense?
Wil
I've been told to do that as well! lol!
