| Home > Technical Chat > Gearbox..something's not right.. | |||||||
24th Dec, 2011 at 02:37:00pm
I've just stripped my SC gearbox, literally, and found this:
Edited by Vegard on 24th Dec, 2011. On 13th Jul, 2012 Ben H said:
24th Dec, 2011 at 02:48:59pm
Ouch On 26th Jan, 2012 Tom Fenton said:
24th Dec, 2011 at 03:23:19pm
JB weld? I run a supercharger and I don't care the TB is on the wrong side.
24th Dec, 2011 at 04:04:52pm
oh dear V that head set looks as if its done no milage at all
24th Dec, 2011 at 04:08:36pm
Do you lock 2nd and 3rd then when dismantling?
24th Dec, 2011 at 04:34:10pm
The correct way to lock the box is to lock first and fourth, The ratios are much further appart. The first motion shaft is also locked to the main shaft meaning the whole gear train is locked.
25th Dec, 2011 at 08:55:53am
Obviously, I didn't lock 1st and fouth, but I didn't use an impact gun, only a long lever. I never had this happen before, but it might have to do with that this was the forst box I built back in 2004 without lock washers, only Loc-tite. Harder to open as I didn't heat anything.
25th Dec, 2011 at 11:54:51am
Ive seen a Minispares set break exactly the same from locking 2nd n 3rd without loctite I seriously doubt it! |
25th Dec, 2011 at 03:45:55pm
This is a Minispares ST set, but I guess it's not the quality of the gears that's the problem but the spannering monkey On 13th Jul, 2012 Ben H said:
25th Dec, 2011 at 08:01:56pm
I broke 3rd on a Tran-X gearset like that. And it wasnt from locking to dismantle.
25th Dec, 2011 at 08:03:34pm
I have done that to a std box once when locking in 2nd and 3rd... |
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
11th Feb, 2012 at 06:03:54pm
When trying to untighten my helical box with two gears locked, teeth from the laygear and one of the other gears sheared off and came at me like bullets. I think eye protection needed for this job.
Edited by dazibee on 11th Feb, 2012. |
12th Feb, 2012 at 08:25:21pm
how did you lock this gearbox and what tools were you using to loosen the mainshaft nuts?
13th Feb, 2012 at 06:04:57pm
We were using a socket and long bar to untighten the mainshaft nuts. It was a remote box with two gears locked (can't remember which gears) When we stripped the box we found the nose bearing on the mainshaft to have disintegrated, which I think is why the teeth snapped off when I tried to undo the nuts |
