Home > Wanted > T2 Compressor Housing
alaskanow0
Member #: 8466
Mansfield
I guys, am after a standard R5 T2 compressor housing. Im planning on updating my turbo with a t25 wheel instead if it's current T28. I therefore need another housing to have bored out. Any
body got anything.
I've got a T2 from a festa with a snapped shaft. Are they the same? It's the 3 bolt exhaust housing but that shouldn't make any difference to you.
F.O.C. if you want it
alaskanow0
Member #: 8466
Mansfield
Thanks Andy, I'll check and get back to you.
alaskanow0
Member #: 8466
Mansfield
I think they are slightly different, have you got any pics?
I'll dig it out later on
Here you go.
The rest of the turbo is there, just no bolts etc and a snapped shaft.
alaskanow0
Member #: 8466
Mansfield
That looks like it should be fine. Any chance you could drop it at Mike's whenever you are around next please. Thanks Andy,
Can do, not sure when that will be though. John boy has moved from round the corner...
Do you want the rest of the turbo?
I'll take it him over. I have to return his hat and gloves.
smashing.
