| Home > General Chat > Electrical issues help required | |||||||
![]() 106 Posts Member #: 9354 Advanced Member |
30th Dec, 2011 at 09:47:45pm
Edited by Funkyp on 30th Dec, 2011. Apparently, I'm Wrong :[ |
30th Dec, 2011 at 09:52:52pm
the cable runs close to the exhaust, it usually needs moving when a performanc exhaust is fitted.
30th Dec, 2011 at 09:54:57pm
Easiest way to check the positive lead is to disconnect it from the battery and put a multimeter on the lead to earth to check there is no continuity to earth. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
30th Dec, 2011 at 09:59:53pm
Joe,
30th Dec, 2011 at 10:06:09pm
normally the worst thar happens is a fire, but sounds like you might get away with replacing the cables. On 28th Aug, 2011 Kean said:
30th Dec, 2011 at 10:06:28pm
The battery may be fried, but I had a similar thing years ago and I just replaced the positive lead. Mine burnt through at the front where the wire meets the subframe next to the exhaust. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
31st Dec, 2011 at 09:36:22am
I've done that when I was a lad - battery positive cable touching the exhaust where it all passes by the subframe. It melted the battery sleeve and made a constant circuit through the exhaust and engine.
