Home > Help Needed / General Tech Chat > Turbo boost gauge
evilbutnice
Member #: 9174
colchester essex
hi all
i know this might sound a really stupid question but i have this turbo gauge
http://www.ebay.co.uk/itm/AUTOGAUGE-52mm-W...=item33701212b8
fitted to my mini turbo at the mo and i was told its reading wrong? so what i was wounding is what the best gauge i could buy for my car i would like it to have a white face as all my clocks are white
many thanks Darren
wez
Member #: 9271
Stoke on Trent
how do you know its reading wrong? just out of interest.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
evilbutnice
Member #: 9174
colchester essex
the guy thats done the rolling road for me said its not reading right something wrong with it?
evilbutnice
Member #: 9174
colchester essex
so i am going to get a new one just really wounded if it matter what type i go for etc
I found that Autogauges were properly cheap and nasty. Pretty much anything else will be an improvement.
I'm using a combination of Tim and SW in mine. They're not too expensive and are all doing what they should still.
Its with asking at this stage if you have it plumbed in properly? Ie on the inlet manifold after the carb butterfly.
evilbutnice
Member #: 9174
colchester essex
evilbutnice
Member #: 9174
colchester essex
dose that look right?
evilbutnice
Member #: 9174
colchester essex
i have been trying to look for the Tim and SW gauges you said but i cant seam to find any?
Its in the right place but you have mix matched bits for the pipe, try and get a single length of tube for it!
I did have a tim boostgauge somewhere i got it for 20 pounds and worked on my mums car when i tested it.
evilbutnice
Member #: 9174
colchester essex
what colour is the face?
evilbutnice
Member #: 9174
colchester essex
http://www.ebay.co.uk/itm/270802730681?ssP...984.m1423.l2649
just found this one.... IS THIS ONE ANY GOOD?
Pull the adapater apart (the one in the centre of the manifold that the small pipe and brake servo connects to) and check it doesn't have a one way valve fitted inside it - I dismantled one a while ago and there was a small valve that prevented pressure going down the line, only allowed vacuum....
Yo-Han
Member #: 3228
North of the Netherlands
I think that should do it.
Demon-Tweeks have them:
Dazed and Confused....
if your running standard boost it would barely show on a 2 bar gauge
if your buying another gauge anyway buy a 1bar or ~15spi one
