Home > Help Needed / General Tech Chat > compression ratio help!!
Clubman_turbo
Member #: 9692
hi.
I am currently building a turbo engine but i can not get my head around the compression ratio calculating. currently my head is 25cm3 and i will be running 10cc omega pistons with a 3.8 head gasket
i would like to achieve an 8:5 ratio but i am unsure that my head has been worked enough for this?
any help will be great
cheers charlie
Craigie-B
Member #: 9468
Wootton Bassett
http://turbo-mini.com/70947.html
Clubman_turbo
Member #: 9692
hi.
thanks, i have just done the calculation and i managed to get 8.7 i think if i did it correctly. would you recommend getting the head taken to 27-8cc size and keep the 10cc pistons rather than going for some 18cc forged pistons.
cheers charlie
wng691s clubby
Member #: 9252
Cleethorpes
if you open the chambers out more you will be able to run higher boost. If you already have the 10cc piston then opening out the chambers of the head will also save you some cash
Edited by wng691s clubby on 5th Jan, 2012.
Done now needs redoing lol
you need 25cc in the chamber for 8.5:1
heres my calc with for a +20 over boar with omegas 10cc dish
1293 cc
323.25 cc
25 cc Head Vol
10 cc Piston dish
3.8 cc Head Gas
4 cc Ring Lands
Total 42.8 cc
compression ratio is 8.55:1
bennyy
Member #: 9037
Doncaster, yorkshire
What cc engine?
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Clubman_turbo
Member #: 9692
hi
thanks for the quick response really appreciated :) The engine has just been freshly bored and is 1293, so by the calculations i should be able to run 12-15 psi safely then.
i am in the process of building the engine at the moment and i have become stuck on which cam to use :S i have heard good things about the avonbar ph2 cam and 1:3 rockers! but i was wondering what you experts think on this set up?
cheers charlie
bennyy
Member #: 9037
For 1293 the ratio is 8.55:1 as Steve said, with a good intercooler 15psi is no problem
Cam wide the ph2 is a great cam, would be by choice, I have one in mine.
Clubman_turbo
Member #: 9692
hi
cheers for all the help guys, i can now order the parts and get the engine done so its ready for summer *happy*
thanks charlie
For reference, I use 20psi on 8.6:1.
