| Home > Help Needed / General Tech Chat > Machining std pistons | |||||||
![]() 146 Posts Member #: 9421 Advanced Member Bardwell, suffolk |
5th Jan, 2012 at 08:56:46pm
Hi guys does any one know of a link or have any info on machining the dish on std turbo pistons been looking but the search button no like me today!!
Edited by 998-city-rat on 5th Jan, 2012. |
![]() 362 Posts Member #: 114 Senior Member Porto/Portugal |
5th Jan, 2012 at 10:12:47pm
Please share what you found Pedro Silva
5th Jan, 2012 at 10:38:37pm
This is the best I have found so far
5th Jan, 2012 at 10:56:12pm
On 5th Jan, 2012 998-city-rat said:
This is the best I have found so far Basically cut the dish 5mm deep with a 6mm radious cutter leaving 5mm from the outer edge at the squish band. that resulted in the most even crown thickness and gaining another 4cc over an unmodified piston. Note though that the pistons were removed from the rods, and that is the difficult bit. Mike that statement sounds familiar And that will give a dish something like this
6th Jan, 2012 at 04:23:52am
Yes mr sprocket the previous statement is all yours it's amazing what that ol search button can bring up, top work |
6th Jan, 2012 at 08:38:59am
I think that picture is of the sectioned piston that accompanied the ones now in the A35 - right, Colin ? |
6th Jan, 2012 at 12:53:37pm
On 6th Jan, 2012 tadge44 said:
I think that picture is of the sectioned piston that accompanied the ones now in the A35 - right, Colin ? Indeed:) On 26th Oct, 2004 TurboDave16v said:
6th Jan, 2012 at 01:04:04pm
The engine in Alex-B's old frag (whereever it is now) also had a very similar set of pistons machined for me, in about 1998, LOL.
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
6th Jan, 2012 at 01:14:49pm
on the pic of the piston it says 5mm deep, 5mm from the edge, but its looks to be machined twice as deep compared to the material thickness left on the outer edge of the piston in the picture.
Edited by wez on 6th Jan, 2012. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
6th Jan, 2012 at 06:12:24pm
On 6th Jan, 2012 wez said:
on the pic of the piston it says 5mm deep, 5mm from the edge, but its looks to be machined twice as deep compared to the material thickness left on the outer edge of the piston in the picture. so does that mean 5mm deep and 5mm dia not radially in from the edge? You shouldn't have gone to SpecSavers
That picture is 5mm deep 6mm rad, and 5mm squish band
6th Jan, 2012 at 06:36:49pm
That picture is 5mm deep 6mm rad, and 5mm squish band ![]() have i missed the distance between the outer edge of the piston and the fire ring on the head gasket then? as that space would account for a certain amount of squish area??? one day boost will be mine!
6th Jan, 2012 at 06:45:39pm
6th Jan, 2012 at 07:15:17pm
the red lines just show up the difference more, if both are supposed to measure 5mm then fair enough. it was just obvious from looking that the 2 areas aren't the same size. thats why i asked about how the measurements are taken. the difference is alot less than the amount i was initially thinking. but i wont bother booking at specsavers just yet, the lines show my eyes work just fine Edited by wez on 6th Jan, 2012. one day boost will be mine!
6th Jan, 2012 at 07:26:28pm
No I think you'll find that my comment on specsavers suggests that you have already been, got their specticles and have worse eyesight, like the thousands of other people that use spec savers for their eye focal correction devices.
6th Jan, 2012 at 07:51:55pm
im not being pedantic at all, just an observation, and i also did just say
the difference is alot less than the amount i was initially thinking. it just looks a lot, around .5 to a mm different, maybe just the photo, if you had of just given a straight answer to my genuine question in the first place instead of winky face's etc it would of been straight forward. like most people im on this forum to learn from others. one day boost will be mine!
6th Jan, 2012 at 07:54:28pm
