Home > Help Needed / General Tech Chat > GT17 compressor housing position.
Billus89
Member #: 8931
Hey guys.
Can anyone using the GT17 post up some pictures or explain the position in which the turbocharger compressor outlet is rotated to. I have had to cut my actuator bracket off so that I can rotate it round the manifold (matty manifold) without fouling and was interested before I make a new actuator bracket, what ange people were position the compressor at. Many thanks.
eden7842
Member #: 8852
leicestershire
just mock it up and put it where suits you best, or look at mine or dig mini threads
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=413417
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=448248
Billus89
Member #: 8931
Thanks buddy :)
I would mock it up and see for yourself.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Look at dig-mini hes doing that now and has put photos up, I think It will help you, Its called winter upgrades.. Alan
Main Build
Upgrade to Turbo
eden7842
Member #: 8852
leicestershire
The second link is digs mate
The beauty of the Garrett turbos is that thay can be rotated to wherever you want. My IHI has fixed positions.
Billus89
Member #: 8931
Thanks for the replies guys. Well I have mocked it up and started to rotate it. Looks like the best place is facing upwards and poiting at a 45 degree"ish" angle back to the bulkhead. This means that the oult is just clear of touching the exhaust manifold and shouldnt get too hot hopefully.
nala56
Member #: 9661
Sorry about that, did not follow any of the links that were put up, it’s just that he's a close friend of mine so he came straight to mind.. Alan
Main Build
Upgrade to Turbo
eden7842
Member #: 8852
leicestershire
just make sure it wont foul your carb as mine just scraped the throttle wen i fitted the boost pipe,
fixed the issue with a British layland service tool
Billus89
Member #: 8931
Cheers eden. Thats a good thought! I need to tyr again with my complete carb assembly in situ.
eden7842
Member #: 8852
leicestershire
i compleatly overlooked it but obv the gt is alot more compact
http://i691.photobucket.com/albums/vv274/e.../DSC_0101-1.jpg
