Page: |
Home > Help Needed / General Tech Chat > Building an engine for Economy | |||||||
1434 Posts Member #: 8466 Post Whore Mansfield |
9th Jan, 2012 at 09:54:55pm
Jean, excuss my ignorance, maybe not, but certainly more than a wet setup, considering need for cam sensor, dual widebands, sampling tubes etc. to do the job properly. As ill need a new head anyway, the SC 7 port looks quite tempting. I plan to make my own plenuem & use MS3 ecu. Class C 3rd Place Avon 2011 14.18 @101mph |
9th Jan, 2012 at 10:00:17pm
It's going to be difficult to package long inlet runners with a 7 port head. And if economy is the priority, that would be an important part.
9th Jan, 2012 at 10:25:41pm
What kind of length are we talking? I could move the plenum under the snatch panel on the clubman. I have about 90mm for the runners if I dont cut the front. ie Head face to plenum. So 150mm in total. Edited by alaskanow0 on 9th Jan, 2012. Class C 3rd Place Avon 2011 14.18 @101mph |
10th Jan, 2012 at 09:37:32am
Another foot should do it :)
114 Posts Member #: 9645 Advanced Member South Wales |
10th Jan, 2012 at 11:02:25am
If you are going to make the plenum anyway isn't it worth considering the 5 port with port injection? The engine could be pretty standard for the performance you are after.
10th Jan, 2012 at 11:21:52am
I would put the extra cost of the wideband, cam sensor and sample chambers at around £200. That's £150 for the 2nd wideband, £25 for a cam sensor in a dizzy body and £25 for tubes and fittings for the sample chambers. If you have your own fabrication facilities, then that should be it.
825 Posts Member #: 2208 Post Whore Essex |
10th Jan, 2012 at 09:48:42pm
On 9th Jan, 2012 theoneeyedlizard said:
For info. Wintersurfer is using 10psi on 8.9:1 and making 150 nanas. |
3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
10th Jan, 2012 at 11:14:06pm
i run a 2.7 on 10's with a T2, i do a lot of motorway in the clubby,
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
11th Jan, 2012 at 07:47:23am
On 10th Jan, 2012 rubicon said:
i run a 2.7 on 10's with a T2, i do a lot of motorway in the clubby, no idea of mpg, but i love the 2.7 on a cruise..... That's great news as I already have the C&P. I was really concerned it would be to high to pull the car off boost. What cc, cam are you running? And where does it boost from. Edited by alaskanow0 on 11th Jan, 2012. Class C 3rd Place Avon 2011 14.18 @101mph |
11th Jan, 2012 at 12:10:54pm
out of interest, what size valves and cam is the 7 port running currently? On 28th Aug, 2011 Kean said:
11th Jan, 2012 at 03:21:36pm
Currently 36x29 valves, smoothed ports, throat area opened up, with SW10 cam, 10.5-1 CR, 1.3 Rockers. It made 101 bhp.
11th Jan, 2012 at 03:56:44pm
The throttle bodies will help with the low end response, but you'll never get that combo to give good road economy.
Edited by Paul S on 11th Jan, 2012. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
11th Jan, 2012 at 03:58:42pm
Ok, thats prety much what i was expecting to hear,
509 Posts Member #: 1027 Post Whore Germini, black forrest |
11th Jan, 2012 at 04:04:37pm
950 turbo diesel on veggi oil... Think out of the box! [X] nail here for new monitor |
11th Jan, 2012 at 04:27:37pm
Paul, I wasnt really concerned about economy previously with this setup and was running 3.44FD. But plans to do the long distance Italian Job run, means I will need a comfortable quiet car. I like the challange to create a turbo'd car that will return 40mpg with a full load and possible trailer specifically for this event. I know I could build a non turbo, but that would be no fun. The Webcon 7 Port really would never be able to return what am looking for and maybe not the SC 7 Port, due to needing longer runner lengths.
11th Jan, 2012 at 04:53:45pm
On 11th Jan, 2012 Paul S said:
For good economy and running a 2.75 diff, you need high torque/VE at 2-3k rpm. So low overlap cam, small valves/ports and effective scavenging are required. Yes exactly, hence thinking of using a SW5 Camshaft as ive already got one or maybe a custom grind with 112-114 Lca on 7 port. I will need a new cylinder head as my MED FIS offset 36x32, large port head with 29.5cc is way be big. Plans for the new head include 33x29 Stainless valves, very mild porting, guide boss removal, 3 angled seats with 26cc to give 9.5-1CR depending on final injection method. (or even maybe a Standard Turbo Head with chamaber opened, boss removed and reconditioned.) Edited by alaskanow0 on 11th Jan, 2012. Class C 3rd Place Avon 2011 14.18 @101mph |
11th Jan, 2012 at 04:59:24pm
For good economy and running a 2.75 diff, you need high torque/VE at 2-3k rpm. So low overlap cam, small valves/ports and effective scavenging are required. Yes exactly, hence thinking of using a SW5 Camshaft as ive already got one or maybe custom grind with 112-114 Lca on 7 port. I will need a new cylinder head as my MED FIS offset 36x32, lare port head with 29.5cc is way be big. Plans for new head include 33x29 Stainless valves, very mild porting, guide boss removal, 3 angled seats with 26cc to give 9.5-1CR depending on final injection method. (or even maybe a Standard Turbo Head with chamaber opened, boss removed and reconditioned.) Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
11th Jan, 2012 at 05:47:43pm
On 11th Jan, 2012 Joe C said:
my next move is a set of bike throttle bodies, (as my plenum is getting a bit tired anyway) on a long manifold to give the fuel time to evap to hopfully get some inertial ramming and pulse gain. that said mine is quite drivable, but i think the low end is boosed by the vnt triyng to come on boost as low as 1800 rpm, So how are going the pull the injections back from the head face? I thought about using the Webcon 7 port head with the AT TB's in the same way but decided against it in favour of a single throttle body. Up until recently I was planning the 7 Port on the trackday turbo, but I think ive decided n/a would provide a more predictable / reliable trackday engine and weigh 17kg less helping me to below 550kg. I dont honestly think any more boost after 10psi will do you any favours on the track anyway. Edited by alaskanow0 on 11th Jan, 2012. Class C 3rd Place Avon 2011 14.18 @101mph |
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
11th Jan, 2012 at 06:05:15pm
I dont honestly think any more boost after 10psi will not do you any favours on the track anyway. Jimster may disagree with that... On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
Page: |
