Home > Help Needed / General Tech Chat > Camshaft installation
Craigie-B
Member #: 9468
Wootton Bassett
Hey guys, was installing my cam shaft today and had some issues.
I as under the impression it would just push in with my hands, but it didnt. I have put in brand new camshaft bearings and lubed them up with the kent lube that came with my camshaft i went to put it in and it wouldnt go into the middle bearing, so i managed to hit it in with a hammer, only when i got it all the way in i noticed there was a long metal shard that had obv come off the camshaft or the bearing, and so i went to take it out with only a little force and it wont budge - it probably would come out if i went to hammer it out but i dont really fancy that
I was just hoping that it was because the bearing i had got was slightly too large as the other two were fine.
Thanks
Craig *oh well*
Edited by Craigie-B on 9th Jan, 2012.
Cams are not interference fit....
Craigie-B
Member #: 9468
Wootton Bassett
*frown* thats what i though
Hammering the cam in??
Seriously, if it doesn't fit then something is wrong. Inspect/measure and find the problem.
Sam
Member #: 1686
Oxford
Seems like an alignment issue to me.
OMG Robert that's a big one
Craigie-B
Member #: 9468
Wootton Bassett
It was aligned straight and how it should have been, how easy are they to turn. I have to puut a spanner in oil pump slot and turn it with a screw driver
you should be able to turn it with 2 fingers.
how did you fit the bearings?
they need to be pulled in gentely with the correct tool and a threaded bar, if you knock them in you will distort them and the cam wont fit.
Craigie-B
Member #: 9468
Wootton Bassett
Fuck, ill take it out tomorrow and see whats wrong with the bearing because something went wrong *oh well*
Craigie-B
Member #: 9468
Wootton Bassett
I had the bearings pressed in with a 20ton press
ah!....
that might have been overkill!
you should be able to see where its contacting from the shiney patch, if its just one spot you might be able to scrape it til it spins.
Craigie-B
Member #: 9468
Wootton Bassett
So i should take the shaft out and see where the shiny bit on the bearing is and then rub it down a little?
If the bearing is fucked amd i need to but another set can you show me how to put it in properly please With a piccie *smiley*
On 9th Jan, 2012 Joe C said:
they need to be pulled in gentely with the correct tool.
I have a fast carl to do it for me *smiley*
this is a v8 but the same general idea,
http://www.cowdery.org.uk/images/v8misc/cambearing.JPG
with the threaded bar you can feel if the bearing is tight in the bore,
also, its a good idea to clean the block bore with a bit of emery cloth, and give it a good wipe and blast with WD40, any crap in the cam bearing bore will cause problems.
Craigie-B
Member #: 9468
Wootton Bassett
Yeah ill have a look tomorrow if its scrap ill get a new one and give southam mini metro centre a call to see if they can do it for me
check the cam too,
Ive had a cam that had a ding on the journel that hung up.
Craigie-B
Member #: 9468
Wootton Bassett
Ok thaank you *smiley*
Did you try the bearings on the cam before installing them in the block? I've had bearings that won't go over the camshaft. They get even smaller when installed.
You could try one of these, but then you should know what you're doing....
http://tools.boxwrench.net/bearing-scraper.htm
Camshaft bearings are soft as cheese and should be treated VERY gently.
I had to scrap my centre bearing in after it was installed. It had a high spot that grabbed the cam.
I used the tool Vegard suggested, very easy to fuck up the bearing if you get it wrong though!
Craigie-B
Member #: 9468
Wootton Bassett
Alright guys thanks for the advice *smiley* chances are ill need a new one, will take the camshaft out today and have a look
Craigie-B
Member #: 9468
Wootton Bassett
Hey guys! So just wipped camshaft out and bearings are fooked!
I tried getting some pictures for you guys to show you the damage
This is the small one:
This is the biggest one:
The biggest one has alot of marking in it you can kinda see it in the piccie, there was alot of shavings off of the bearings as well so spent about half an hour with a torch getting them all out. Going to get some more and im ringing southam mini metro center tomorrow to see if they can put them in properly for me.
Thanks for your help guys *smiley*
Very nice focused pictures.
Craigie-B
Member #: 9468
Wootton Bassett
sorry my iphone is crap =[
That's a surprise? *tongue*
Hate the bloody things.
The camera in the iPhone 4S is great.
The 3GS was shocking! Looks like they were taken in murkey water!
Have you got another camera? You can barely make out the areas of concern.
