Home > Help Needed / General Tech Chat > Valve springs
supermotolee
Member #: 2153
kings langley
Hi does anyone know the fitted length or the pressure you should achieve at full lift with a phase 2 cam?
t@z
Member #: 452
Chester, UK
bumping this as it went into the pit of zero replies :)
www.twitter.com/lilpinkiy
It depends on which springs are being used. They should be fitted as per the manufacturers spec - the cam choice is irrelevant
