Home > Help Needed / General Tech Chat > subframe rebuild/ upgrade
adrian
Member #: 2726
wakefield
Going to be rebuilding my subframes soon. Got red dot cones, the protech dampers, adjustable arms n tie bars along with rebuild kits for radius and front arms. Anyother upgrades I should consider? Is the area around the driveshaft hole double skinned as I fancy enlargeing it but not it will need welding after (welder needs fixing).
Also read sumwhere that using hydro top arms on my dry setup will improve handling?
Any help/ info would be great.
Adrian
The socket cup for the knuckle on hydro arms is further outboard so gives a stiffer effect on your cones by giving more leverage.
Use solid mounts to attatch the subframes
adrian
Member #: 2726
wakefield
Thanks p!ul, thats interesting.
I am running wet top arms and i like how it holds to the road.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Do away with all the rubber and use rose joints through out.
Own the day
Oh, not for a road car. Nice polly bushes will be good enough withe the solid mounted frame
adrian
Member #: 2726
wakefield
Read somewhere about mixing polybushes and uprated minispares bushes together to stop the polybushes from cracking/splitting? Does that sound right or shud i just order a polybush kit?
To be honest the quality of the repro rubber bushes these days are rubbish and by the time you fit them they'll need doing again..quite literally! lol
Poly bushes are a much better bet for the long term.
adrian
Member #: 2726
wakefield
Polybushes and solid mount subframe it is. Ote else?
Mr Joshua
Member #: 1954
Luton Bedfordshire
And that is what I love about this forum variety in build spec mine is solid through out and I get the feel I want some say to stiff for a road car and it will rattle your teeth out some say poly it's too stiff as well. May this site continue the debate.
Edited by Mr Joshua on 13th Jan, 2012.
Own the day
adrian
Member #: 2726
wakefield
Also are them minispares offset bushes for my adjustable arms needed.
I just bought the adjustable suspension kit from minispares - had bottom arms, tie bars and all the bushes etc you need. The kit had a mixture of rubber and poly bushes, so I'll see how I get on with them and how long they last...
Based on this, anybody got a spare set of wet to arms?
adrian
Member #: 2726
wakefield
If I'm not going to lighten my frame with holes would you bother to stiffen/strengthen it ?
Adrian
Lots of us brace the bracket at the front for the bottom arm tie bars
adrian
Member #: 2726
wakefield
Think ill have a look n see if i can see some of them brace bits, lightening the top arm seems a good idea too.
