| Home > General Chat > Boost | |||||||
40 Posts Member #: 101 Member |
5th Dec, 2003 at 09:25:09pm
Does anyone know: |
5th Dec, 2003 at 10:07:04pm
with the std actuator it should show 4-5 psi... with the metro control unit is will peak at 7psi at higher revs...
AlexF |
6th Dec, 2003 at 09:37:54am
I'm running a bleed valve which controls the boost between 8-12 psi (I have a 8psi modified actuator) and I have a valve that blocks off the run from the actuator which lets the turbo spin up as high as it can go..about 15psi.., I just wondered if the T3 is capable of producing more?
6th Dec, 2003 at 01:44:34pm
well there is no std intercooler so anything is an improvement!
AlexF |
6th Dec, 2003 at 05:01:23pm
Cheers |
