| Home > Help Needed / General Tech Chat > Hello, greetings and MPI Idle intermitant/loss of power problem! | |||||||
6 Posts Member #: 9755 Junior Member Zomerrrzet. |
15th Jan, 2012 at 07:36:16pm
Hello, nev_payne (same one from TMF) seeking help. I'm "that stupidly tall guy with the Knightsbridge". Over the last 4 years it's undergone a nut and bolt restoration, and as of mid-December is now back on the road. Not without teething problems, but that's breaking in for you.
15th Jan, 2012 at 07:38:24pm
18th Jan, 2012 at 09:13:21am
Anyone got an idea?
976 Posts Member #: 3228 Post Whore North of the Netherlands |
18th Jan, 2012 at 09:24:26am
Welcome to TM.
Dazed and Confused.... |
869 Posts Member #: 2443 Post Whore Cheshire |
21st Jan, 2012 at 01:24:05pm
31st Jan, 2012 at 11:32:46am
The engine specs:
Edited by nev_payne on 31st Jan, 2012.
31st Jan, 2012 at 01:00:05pm
I guess this is also on the standard ECU then?
![]() 580 Posts Member #: 9580 Post Whore Surrey |
31st Jan, 2012 at 01:11:33pm
Did you re fill the tank with fresh fuel?
Edited by shellspeed on 31st Jan, 2012. |
31st Jan, 2012 at 01:23:02pm
Yup all standard on the electro-magicals.
31st Jan, 2012 at 04:26:31pm
Yes just a bit of brake cleaner or petrol and a rag.
31st Jan, 2012 at 04:28:55pm
Sorry just re read the post and im starting to lean toward the idea that this is an air leak on the inlet manifold gasket. even a tiny oner on the MPI plays buggery with the whole thing.
31st Jan, 2012 at 05:18:01pm
usualy stuff like this points to an air leak on the intake manifold but with the mods on the inlet side i would guess the bigger tb and the k&n are the reason to it being lean, have you got a wideband or access to something to measure its fueling?
Yes i moved to the darkside |
31st Jan, 2012 at 07:45:21pm
You need to get that on a diagnostic and look at the stepper motor function when it is doing this.
31st Jan, 2012 at 09:13:22pm
Burlen 48mm replacement t-body
31st Jan, 2012 at 09:49:59pm
The Burlen throttle body is a dirrect replacement alloy body for the standard plastic Rover one. It shouldn't cause any issues, unless it leaks On 26th Oct, 2004 TurboDave16v said:
31st Jan, 2012 at 10:21:39pm
Indeed 48mm is standard, but they do do a 52mm as well. |
1st Feb, 2012 at 11:37:16pm
Wow, thanks for all the replies :) The IACV was loaded with carbon for starters. After a clean and a check of the breather hose:
Edited by nev_payne on 1st Feb, 2012.
2nd Feb, 2012 at 08:47:10am
Great stuff, glad your making progress! |
2nd Feb, 2012 at 10:27:08am
nev have a look here http://www.ebay.co.uk/sch/i.html?_nkw=aem+...6.c0.m270.l1313
