Home > Beginners Tech > help
1994alex
Member #: 9757
Solihull
hi,
I am planning on doing a turbo engine, and have read that you are able to get an engine with high bhp and torque. Could anyone tell me how to do this, what is needed and so on.
Alex
mw3
Member #: 9590
Derby
Money, time and skill
Matt W
On 14th Mar, 2012 mw3 said:
1994alex
Member #: 9757
Solihull
I know that *tongue*
Have a look at this:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=348364
EDIT: Horsepower is a function of speed and torque, so if you get the torque then the horsepower will be there. Don't expect off-idle torque with a turbo, they need time and rpm to get working.
Edited by Paul S on 16th Jan, 2012.
1994alex
Member #: 9757
Solihull
That is helpful *happy* thanks, but a few questions
Do you have to bore the block out to get to the 200bhp?
With the rods what does H section mean?
Also concerning the block what does 4 bolt c mean?
what inter coolers would you use?
What does a hybrid turbo come off?
Sorry for all the questions :/
Alex
I suggest that you should now use the Search function to answer your questions. The answers are all here.
Do you have to bore the block out to get to the 200bhp? - no, but most are due to the availability of sizes of uprated pistons.
With the rods what does H section mean? It means that the cross section of the rod is H pattern. Ps these ate not needed for 200hp.
Also concerning the block what does 4 bolt c mean? 4 bolt centre main. This is an uprated centre main bearing cap. Also not needed for 200hp.
what inter coolers would you use? Whichever you can get to fit. This is desireable for 200hp.
What does a hybrid turbo come off. A hybrid turbo doesn't come off anything. It is a turbo that has been modified by using parts from another model.
Search, get reading and have a look at what's been done.
Edited by theoneeyedlizard on 16th Jan, 2012.
wng691s clubby
Member #: 9252
Cleethorpes
200bhp is alot not saying its not possible as a few have reached this and beyond just take a lot of reading understanding and money
Done now needs redoing lol
almichie
Member #: 2065
A LOT of money....
Shaft seems nice and snug
...And balls.
It's easier now than it has ever been. All the information is on this site.
just swat well up
hazpalmer
Member #: 9038
Carlisle, Cumbria
do a lot of reading using the search function, and pluck out all the key information.
