| Home > Help Needed / General Tech Chat > Can a VNT turbo be squeezed in without bulkhead modifications | |||||||
3 Posts Member #: 9759 Junior Member |
16th Jan, 2012 at 08:38:44pm
Great forum! With a lot of super knowledge for at beginner.
1083 Posts Member #: 8932 Post Whore |
16th Jan, 2012 at 09:32:09pm
The VNT 15 is an upgrade of the gt15 from what i can find, and considering its smaller than the commonly used gt17 it should be no problem. |
16th Jan, 2012 at 09:40:05pm
If you fancy a VNT, you'll need to go a lot larger than the 15.
In the 13's at last!.. Just |
16th Jan, 2012 at 09:42:39pm
Also, I'd have thought that you would need a bulkhead box with a VNT because the exhaust housing is usually larger to contain the variable vane gubbins.
16th Jan, 2012 at 09:58:39pm
Plus the acuator sticks out the side... usually in the most awkward place possible.
17th Jan, 2012 at 03:45:33pm
Thanks for the ansvers.
53 Posts Member #: 9404 Advanced Member Cambridge |
17th Jan, 2012 at 05:14:28pm
Just bite the bullet and bang a bulkhead box in!! |
17th Jan, 2012 at 05:29:40pm
You will need an external wastegate if you are adamant about using that turbo.
17th Jan, 2012 at 05:31:16pm
On 17th Jan, 2012 j_f_jensen said:
Thanks for the ansvers. Its a GT1749LV hope that it is large enough for around 90~100HP. The exhaust house is approximate 135 mm at the largest place and the same is the presure house. Do you think that there is space for this? If any of you have pictures of installations without bulkhead modifications then I would like to see them before i start taken it all apart. Why not measure the space you have between the block and bulkhead? On 11th Feb, 2015 robert said:
17th Jan, 2012 at 09:56:14pm
Hi apbellamy, I have tried, but to get good measurement I think that I need to remove the injection etc. And I would like input from you who have done it before and know all the secrets 8-)
