| Home > Help Needed / General Tech Chat > Follower recommendations? | |||||||
614 Posts Member #: 2153 Post Whore kings langley |
18th Jan, 2012 at 01:05:57pm
As title really what ones are best? Lightest? Most durable?
18th Jan, 2012 at 01:11:02pm
I would imagine isky ones are best.
18th Jan, 2012 at 01:37:40pm
I've used the Minispaes ones with the oil hole for years, no problems, cheap too. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Jan, 2012 at 01:39:24pm
There u go then. If they are good enough for wil they are good enough for me. If something is worth doing, it's worth doing half of. |
18th Jan, 2012 at 07:11:33pm
Thats all I have ever used on all my engines and all those that I have built for others, with no comebacks at all. |
18th Jan, 2012 at 07:49:26pm
as above but on silly spring pressures
18th Jan, 2012 at 08:50:10pm
do any of you guys check the spring pressures at full lift as i now have a tester at work and have been doing more of it recently on the engines to bring pressures down to save the cams and followers and have not been getting valve bounce, i run around 140lbs @ full lift on the 2 litre bristol engines and rev them to near as damit 7k without problems so far and just would like some input on where i should be aiming for with my own build..
18th Jan, 2012 at 11:10:26pm
I used none hole followers for that very reason. But see above - people have not had problems....
