| Home > Help Needed / General Tech Chat > Alternator Lamp | |||||||
78 Posts Member #: 6322 Advanced Member Bawdeswell, Norfolk |
20th Jan, 2012 at 12:23:40pm
Morning all.
20th Jan, 2012 at 12:28:51pm
I'm not sure if you're familiar of how the charging light works, it has to be a bulb so that the current can flow both ways through it. If the alternator is fine, the current at both ends of the bulb are equal, and so doesn't light up, if the alternator gives in, the current flows battery to alternator and the charging light illuminates telling you there is a fault, and vice versa. Hope that helps somewhat :) Edited by Carlzilla on 20th Jan, 2012. On 26th Jan, 2012 Tom Fenton said:
20th Jan, 2012 at 12:37:08pm
Clearly I dont then! I just went by the MPI loom wiring diagram in the Haynes manual (my loom is a modified MPI loom) and (I haven't got it infron of me) I was sure it showed an diode inline before the bulb... |
20th Jan, 2012 at 12:51:11pm
Bear with me and ill have a look in my haynes! On 26th Jan, 2012 Tom Fenton said:
20th Jan, 2012 at 12:57:47pm
On the wiring diagram for my car, (89) you should have brown/yellow from the alternators charging pin, and then white from the ignition feed, one at each end of the bulb. On 26th Jan, 2012 Tom Fenton said:
![]() 580 Posts Member #: 9580 Post Whore Surrey |
20th Jan, 2012 at 01:08:02pm
That explains why mine does not work properly as I earthed the otherside to the brown/yellow on the bulb. Spot of wiring this afternoon then. Cheers |
20th Jan, 2012 at 01:09:19pm
the white powers the alternator. you should also have white to the clocks to provide the other side of the circuit On 11th Feb, 2015 robert said:
20th Jan, 2012 at 01:29:09pm
its been baffeling me since i made the wiring loom last year RTFM |
