| Home > Help Needed / General Tech Chat > Oil cooler and temperature sensor | |||||||
134 Posts Member #: 9579 Advanced Member Tadley, North Hampshire |
21st Jan, 2012 at 02:21:28pm
Hi folks. Whilst tackling a number of winter jobs prepping the mini for the track (April hopefully) I've been thinking about oil temperatures. I'm running a metro turbo but no cooler and I don't have a temperature sensor or oil cooler. I'm thinking both would be recommended, I'd obviously look to fit the sensor first to get a baseline. Anyone any thoghts or recommendations on what to purchase, and if indeed I should be concerned in the first place? Cheers. My build thread: http://www.turbominis.co.uk/forums/index.php?p=vt&tid=440970 |
21st Jan, 2012 at 05:08:02pm
if your tracking the car an oil cooler is needed 6 row will do it
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
21st Jan, 2012 at 05:09:31pm
I've got a water oil cooler from a na mg engine got a temp gauge with 1 of them mini sport sump plugs make easy fitment of gauge & my temp is around 70deg if I remember right (as rebuilding engine so havnt drove it for a while now) hope this helps |
21st Jan, 2012 at 05:11:11pm
Also have a mocal 13row cooler with pipes for sale if interested? |
21st Jan, 2012 at 10:54:05pm
you may also consider fitting an oil stat Own the day
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
21st Jan, 2012 at 11:59:43pm
I've thought about the sump plugs with the sender adapter, do people recommend these? On 25th Sep, 2009 mini13 said:
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
22nd Jan, 2012 at 10:08:08pm
Thanks for the advice folks. Going to invest in a sensor first to benchmark and then go down the small oil cooler and thermostat route. Probably a 10 row cooler as this is a small as the Mocal coolers go.
