Home > Help Needed / General Tech Chat > Which pistons
benspickup
Member #: 9608
Lincolnshire
Which pistons are best for reliability and cost when using around 15psi of boost. I'm running a metro turbo carb and dizzy and a intercooler from a calibra. I don't want to spend a fortune but don't want to waste my money on crap! Also what ball figure power should I expect with this setup? Cheers Ben
std turbo pistons are fine, but the prefered one are accralites, but as long as you go for a good quality piston and dont run it lean or in det you'll be ok.
Omega's are a good bet too.
im on cast omegas but there alot more expensive now, there is a couple members running 21253 pistons, iirc these are cheap and have been used upto around 20psi, so at 15psi shouls be a great cheap piston
just dont go lean or into det *wink*
scott the joiner
Member #: 9229
newcastle upon tyne
Std for me using them in my new build witch will be goin in the car next week (hopefully) with total seal rings
benspickup
Member #: 9608
Lincolnshire
Are the 21253's AE pistons or the like? I would like to stretch to the omega,s ideally as even standard turbo ones are 200 quid a set so may aswel push the boat out a bit more and get some fandangos!
personally I'd pay the extra for a set of cast omega's.
benspickup
Member #: 9608
Lincolnshire
My thoughts too! Do it once and right, and hopefully if I do have issues, they,l cope better with them! Where would be recommended to get them from? Ideally I'd like to take my block and get it bored out at the same time!
MED have sole rights to Omega pistons and Swiftune sell them under license, so one of those two
tadge44
Member #: 2500
Buckinghamshire
This subject has been comprehensively covered quite recently, as a search will reveal.
benspickup
Member #: 9608
Lincolnshire
Indeed and I had searched the subject of pistons, however it is still useful to get input as I guess everyone's engine spec will differ in one way or another, thanks for everyone's help!
Me too!
